Question about Coleman Mach III Air Conditioner
What type of coolant is used in my coleman home a/c unit?
    President:
  • 635 Answers
R-22
Posted on Jul 31, 2010
Convert coleman eb15b to natural gas unit
Sorry there is no way to convert it to a gas unit.. The only way is to replace the furnace with a natural gas unit. You will need a gas line ran to it and a Flue. and then room to fit everything in that space.
Nov 10, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
How do you know when to recharge ac unit. What type of freon>
Depending on what the issue is, most sealed units never require a charge to the unit, they are factory sealed and usually don't leak. If the unit keeps freezing in the condensing coils and the unit is clean and an un obstructed clean air path is established and if the compressor is not bad, that would tell me you are low on freon. This is listed under Coleman air conditioners which tells me that this is a sealed unit and to get a charg would require someone to cut the lines and insert valves to add a charge since they don't have these already on them coming from the factory. This is unusuall and will cost you several hundred dollers to get it done. Depending on the age of the unit will tell us what gas is in the unit, pre mid 90's it is probably freon after around 95 they started using R-34 coolant. It should be marked somwhere on the unit what the gas is and how much is in it.
Jul 08, 2011 | Coleman Heating & Cooling
My coleman 7900 furnace blower cycles on and off while burner continues to operate
I would look at fan limit switch. They are normally located in electrical cotrol compartment. If your are lucky you will have one thats adjustable. It would helpful if I knew is your home a mobile or modular home as they usually use a button type limit on fan and hi limit. It sounds to me like you may be having problems with fan limit which controls temp. that fan comes on . Often what happens is that switch scenses temp to turn on and then draws cold enough air on return air to shut back down until temp.rises again.If this occurs when unit first comes on or continues after burner shuts off you can get a limit switch with a higher temperature rating or one that has adjustable temperature range. Hope this helps you.Thanks.
Nov 06, 2010 | Coleman Heating & Cooling
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Aug 30, 2010 | Coleman Heating & Cooling
I also need a wiring schematic for a Coleman 3500A816 furnace
What are you wiring? Possibly we can help.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 24, 2017 | Coleman Heating & Cooling
I HAVE A COLEMAN AC CANNOT FIND FILTERS TO FIT
yOU CAN PURCHASE FILTER MATTING AT ANY HARDWARE store and cut to size. Its cheaper anyway.. It comes in rolls.
Jun 05, 2009 | Coleman Propane Forced Air Heater...
Looking to find an owner's manual for an old furnace
I remeber we took out a Coleman kero heater out of my grandmothers mobile home. Just had it repaired but she wanted a new unit. Would have to go and check to see how many BTU's it is and also to see if the book is there as well.
Jan 29, 2009 | Coleman Heating & Cooling
Coleman Mach III Air Conditioner Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
