Question about Canon PIXMA MP240 All-In-One InkJet Printer
Paper will not feed through after replacing color
Paper will not feed through rear tray after replacing color ink cartridge. I have checked ink cartridges several times and appear to be installed correctly. The paper begins to feed from rear tray on the left side then suddenly stops and jams. Any idea what the problem may be or a solution???
  • 906 Answers
Good day, I suggest you must clean the roller and and use appropriate type of papers. to clean the roller, press power button to turn on the machine then remove any paper from the auto sheet feeder. press menu until maintenance appear the press ok. and try to load load 3 or more a4 letter sized paper and see if the the paper is automatically fed in and then out of the machine.
hope this will help you. have a nice day.
Posted on Aug 01, 2010
LaserJEt 2100
Hi, try this.
Feed paper in tray 1.
If this works fine you better replace the roller and separation pad in tray 2.
To test where the swath of ink is comming from try this:
Feed papaer in tray 1.
Send a printjob. As soon as the paper is in the machine open the topcover.
Remove the cartridge and take out the paper carefully.
Check if the swath of ink is all over the side or only there where the paper was in the fuserunit.
If it is all over the side, the cartridge is defective. If its is only there where the paper was in the fuserunit you will have to replace the fuserunit.
Good luck,
Gerrit Jan
Jul 21, 2009 | HP LaserJet 2100 Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 20, 2008 | HP PhotoSmart InkJet Printer
Print fragmented documnts
Step1
Step
Step
Step
Aug 14, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer stuck on Perfoming Self Test
Step1
Step
Step
Step
Jun 02, 2008 | IBM Infoprint 1120 Laser Printer
Light blinking
Step1
Step
Step
Step
Jun 02, 2008 | Epson FX 1170 Matrix Printer
Print out very light
Step1
Step
Step
Step
Apr 17, 2008 | HP LaserJet P3005dn Printer
Paper completely jammed
check if there is a little paper that stuck on it that causes a paper jam
Mar 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer powers up, then down
Step1
Step
Step
Step
Dec 28, 2007 | Tally Line Matrix T6090 Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
