Question about Compaq Presario 700 470024-192 Notebook
Hello my microphone is not working from little far distance when i take mouth nearmike then only i can hear
    President:
  • 2,571 Answers
Go into the sound properties and adjust the record/mic audio levels
Posted on Jul 31, 2010
Samsung Monte, faulty microphone, doesn't work during calls
Get it Replaced from samsung service center.
Jul 05, 2011 | Cell Phones
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
Husband's phone (samsung rugby SGH-a837) again. :( his phone receives call, his phone can dial calls, display ok, but we can not hear him, he hears us ok. Can the mic be replaced? Can the phone be...
Hello
OK, this is could be one of two scenarios. It could either be the microphone circuit on the cell circuit. Or, this could be just the microphone itself.
It is most likely the microphone itself. This can be repaired. Unfortunately, warranty does not cover water damage, hence, you will need to repair this on your own cost. It will cost around $30 - $50.
Hope this can be of help.
Kind regards
Andrea
Aug 09, 2010 | Samsung Cell Phones
Hi I have just purchased the Nokia E63 a few days ago. When i make or receive phonecalls i can hear the caller but they cant hear me! Whats going on? Can someone please help! Thanks
Have your unit brought back from where you bought it, the phone mic piece or microphone is damaged this should be replaced, thats why they cant hear you.
I would not recommend it replaced by yourself, this would void your warranty, and e63 phones is quite sensitive
Aug 08, 2010 | Nokia E63 Cell Phone
Microphone on my Nokia 6111 is not working, when someone calls me I can her him but he cant her me,can someone help me?
The problem is that the mouth piece of your phone is bad that is why the cannot hear your voice.
I advice you get the mouth piece of your phone replace because it is bad and that is why your callers cannot hear you.
All you need to do is to change the mouth piece of your phone and you will see that your callers will hear after you have replace the mouth piece of your phone.
Meanwhile, you can get hands free pending the time you will replace the mouth piece of your phone.
Take care.
Aug 04, 2010 | Nokia 6111 Cellular Phone
The microphone on my Samsung Impression apparently isn't working. People cannot hear me when I call them or hear me when they call me. Is there a setting for the mic that I can check or what to do about...
The problem is that the mouth piece on your phone is malfunctioning that is why people call or people that calls you barely hear you.
All you need to do is to replace the mouth piece of your phone and you will see that after the replacement of the mouth piece, anybody that call you or people you call will hear you clearly.
Just change the mouth piece as advice and you will see that the problem is solve. meanwhile, you can be using hands free pending the time you will replace the mouth piece.
Take care
Jul 19, 2010 | Samsung SGH-A877 Impression Cell Phone
I can hear callers but they can't hear me. I can't figure out what has changed on the phone (was working fine for months) or how to raise the volume being transmitted back to the caller. Any ideas?
Take your phone off of "UnMute". It may seem a little backward at first. When you see MUTE on the screen, it is giving you the opportunity to mute your phone. In other words, you're good. If it says "UNMUTE", you have muted the phone. All the stuff in the previous post is a little over the top.
Jun 10, 2010 | LG Flare Cellular Phone
The microphone of my cell phone isn't working
since it fell down, the mouth piece (microphone) must have shifted from its right position or loosed contact from the phone board.
You need to loose the phone and set the mouth piece to the right position and the problem would be resolved.
Take care.
Jan 14, 2010 | Dual Electronics CECT P168 Cellular Phone
Verizon Gleam Microphone volume not working?
the mouth piece of your phone is faulty. This needs to be replaced for other people to hear you when on calls.
You can use an hands free (ear phone) to make and receive calls still you replace the mouth piece.
I wish you the best of luck.
Take care.
Jan 04, 2010 | Verizon Communications Samsung Gleam Cell...
I can hear my voice in the headphone, and the other caller cannot hear me
The fault should be from the mouth piece of your phone.
Use a phone screw driver to loose the phone, remove the mouth piece and clean the phone board, especially the mouth piece area of the board. Put the mouth piece back and make sure it contacts the phone board very well. Couple back the phone and test it.
If it still gives the same fault, the I think you need to change the mouth piece completely.
If you cannot get another mouth piece, then I would advice you get a hearphone to receive and make calls for the main time, till you get another mouth piece.
Dec 28, 2009 | Nokia 6070 Cellular Phone
Compaq Presario 700 470024-192 Notebook Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
