Question about Sta Rite Max E Pro 1 12 Hp Up Rate Standard
High Pressure: STARITE 1.5 hp pump designed to
High Pressure: STARITE 1.5 hp pump designed to generate 20psi, system is jumping to 40 psi within hours of cleaning cartridge filters. Filters don't look to dirty, but we replaced them anyway and still have the same pressure problem. Is it an impeller issue?
  • 8,404 Answers
It is a cartridge issue in my opinion. I dont recommend cartridges ... Sand is so much superior as a filter medial. If this is an option for you ... I recommend it. If not an option, you might be able to get a different type cartridge that will filter at a lower rate and not get as dirty as fast ...
Posted on Aug 04, 2010
Pump shuts off at 20psi
you need a new pressure switch or adjust the old one for a higher limit ,
Dec 30, 2015 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
Pump loses power
if impeller is not clogged check on recirculate if ok change sand
Jun 05, 2013 | Sta Rite StaRite Duraglas Pump 1 12 HP...
PUMP JUST RUNS AND WONT SHUT OFF MQ3-45
DOES THIS SYSTEM FEED YOUR HOME.DOES IT HAVE PSI TANK. WHAT COULD BE HAPPENING.IS.THERE IS A PRESSURE SWITCH (fyg-2) THAT WAS INSTALLED ON YOUR SYSTEM. THIS ITEM, DEPENDING ON IT'S MANUFACTURE.COME PRESET AT 20/40 PSI OR 30/50 PSI OR 40/60 PSI. THAT MEANS ON START/OFF START PSI. SO IF YOUR PUMP CONTINUES TO PUMP AND WON'T TURN OFF.YOUR SYSTEM PUMPS MAY HAVE SOME WEAR TO IT OR A POSSIBLE HOLE IN THE DROP PIPE THAT IS NOT ALLOWING YOUR SYSTEM TO REACH PSI THAT IT SET FOR. ALL U HAVE TO DO IS READJUST THE PRESSURE SWITCH TO THE PSI READING THAT IS ON PSI GAUGE.
Oct 28, 2011 | Grundfos MQ3-45 1 HP Pressure Booster...
On my 1996 ss impala what low side pressure should I see on the a/c with the system running
It all depends on the outside (ambient) air temperature. Your A/C low pressure switch is designed to turn the compressor off at 24 Psi. and turn it back on at 45 Psi. Most systems will normally run at between 25 and 40 Psi when the system is running on HIGH blower and "MAX" or "RECIRCULATE". A system that is fully charged may run at 25 Psi when the ambient temperature is 75 Deg. (F) and may run at 40 Psi when the ambient temperature is at 90 Deg. (F). (it can be even higher if ambient temperatures are higher than 90 Degrees.)
To properly diagnose a malfunctioning A/C system, the HIGH side pressure must also be checked. Restrictions in the system can make the low side pressure look normal while the high side pressure is high enough to blow hoses apart. (400+ Psi.)
Sep 04, 2011 | 1996 Chevrolet Impala SS
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a Guundfos CHIE 4 circulation pump that is constantly running. I closed the valve on the pressure side but is still runs. On a previous post I was told it "may have lost its prime". The pump is...
You have a defective pressure switch.But replacing the switch. Do the following; Open the pressure switch cover, and find the two adjusting nuts. One is for the cut-off pressure (40psi) and the other is for the cut-in pressure (20 psi). Adjust the the nut with a longer stem counter clockwise (loose) with the pump running. Take care not to touch the power line attach
to it. Continue the adjustment until the pump stops,
at 40 psi. Then, observe - Pump must stop once the
pressure is attained. Then, open the valve until it
start (20psi).. Then you can adjust the other nut to
cut in at 20 psi.
To prime the pump; open and fill the priming port full
with water.and replace the priming port plug. Set
the water flow control valve at full close position.
Switch the power on to run the pump and slowly
open the control valve to appropriate setting such
that the pump doesn't lost the suction. Send your e-
mail for further comment. God bless u
Aug 07, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Pool over fills
It depends on the actual valve. The valve that comes standard with the system is designed for typical municipal water pressures of around 35 to 40 psi.
It is easy to replace the valve for one with higher pressure ratings.
Jun 17, 2009 | Jandy Levolor Water Leveling System - Fill...
Oil Pressure Suddenly Reading in High and Low Ranges
either the oil pressure sender is defective or the pressure relief ball valve in the oil pump is sticking, my money would be on the oil pump pressure relief valve ball sticking.
May 27, 2009 | 1998 Dodge Intrepid
Sta Rite Max  E  Pro 1 12 Hp Up Rate Standard Logo
143 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
