Question about ViewSonic VP920b 19" LCD Monitor
Viewsonic VA720 monitor just stopped. The power light is off. Is there a way to check the problem or need I take it to a shop?
  • 11,361 Answers
Look for bad caps: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 06, 2010
    President:
  • 2,571 Answers
If the power light is off, have you checked the power cable, or the fuse in the plug?
If thats all ok, maybe time for a new monitor if not under warantee.
It may cost more than the monitor is worth to try getting it repaired
Posted on Jul 31, 2010
4 Suggested Answers
noone
  • 105 Answers
SOURCE: ViewSonic VA720
The VA720 I have has 4 screws from the back: 1 at each bottom corner and 2 in the middle lower at the base. Remove screws and carefully pry the front and back halves apart. They snap together. Usually working the bottom apart first is easiest.
Posted on Oct 12, 2006
SOURCE: viewsonic VA720 monitor has small blinking light, won't turn on
When turning on the computer we get analog auto save, and don't get as far as the desktop, how can I solve this problem
Debi
Posted on May 04, 2009
rulds2008
  • 3866 Answers
SOURCE: Viewsonic VP2030b LCD monitor - No power
There should be one fuse in the power supply inside. You can check and replace that if its dead. now if its not dead and you got power to that point you do need to rule out any capcitors at that time but if the fuse is gone it will not hurt to check the rest of the supply for the fault.
Please rate and accept the answer if it did help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 18, 2009
ViewSonic VA720 monitor will not turn on just a blinking light.
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 17, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic va720 monitor flickers / goes a little dim. wiggling the power cord often helps.
then change the power cord...there may ba loose connection...or the pins int he cable is not getting full power
Dec 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA720 monitor has small blinking light, won't turn on
Debi
ViewSonic VP920b 19" LCD Monitor Logo
66 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
