Question about Dishwashers
Amana Sofsound 1 door will not open
For the last month, the release handle would not open easily. Not it won't open at all.
You will be able to open the door by unplugging machine, remove top cover and look down to door. YOu will see a cable running from door latch up towards the motor.
This cable will need adjusting.
Either that or the door latch is broken/scratched.
Hope this helps?
Posted on Jul 31, 2010
What would cause the rear door latch to work correctly when unlocked, yet when locked to completly release the door so it can open on it's own?
Make sure that the striker plate is adjusted right. Most have an adjustment you can set. you may need a special wrench.
Aug 30, 2014 | 2001 Toyota Sequoia
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
How to remove sliding door inside panel of Mazda MPV
1. Work with slider in open position. It helps if you are on a slight incline so that door stays in fully-open position and won't slam shut on your fingers.
2. Remove inner handles and door panel:
a) Inner handle. Remove the inner handle first. You can't see it too easily but a wire clip about the same thickness as a large paper clip holds the handle to its shaft. It's shaped like an upside down "U" so it needs to be pushed straight up. Press the panel outward around the handle and you can just see the clip. Use a small thin screwdriver to locate the bottom tips of the clip and push it up. You may have to alternate from side to side but it will pop off. Grab it with a pair of needlenose pliers if you have to. The door handle willl now slide off - just pull it towards you.
b) Power window switch. Remove power window button by squeezing hidden tabs along the sides of the button. Again, you may have to push the panel outward a little and pry the switch to see the tabs. Wiggle it a little and the button will release. Pull it out and unplug the wiring harness.
c) Door panel. There are several plastic buttons which hold the panel on at the bottom and up the sides. Use a plastic putty knife to get behind panel and pop it out of the holes.
3. Once all trim fasteners are released, grab the door panel at the bottom and pull straight up to release it at the top. You may have to give it a quick upward tug to get it to release. Push the power window button wires through the mounting hole. Look at the panel buttons to make sure that all of them came off with the panel. If not, remove the remaining ones from the door and put them in their respective slots on the door panel. (Trying to re-attach the panel without the buttons installed on the panel will be frustrating.)
4. Outer handle removal.
a) Unclip the handle lock button / bar by turning the small tab and pulling the bar out of its slot. Hard to describe here but you'll figure it out once you see it.
b) Remove three bolts which hold the handle on the door. Note that one bolt is accessible from the outside of the door along the front jamb.
Replace handle and reverse the steps above.
Notes: Check the locking mechanism and make sure the door opens and closes before you reassemble the panel. Remember to orient the inner handle the right way before you re-attach its spring clip. (I've attached it upside down and it won't work!!!) . Also, be sure to feed the power window wiring harness back through the mounting hole before putting the panel back on.
Nov 06, 2012 | 2000 Mazda MPV
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Amana SR520S with NO ice dispenser
1. Unscrew the philips screw at the top of the door handle and take off the cap.
2. Go to open the door and your knuckles will be touching a cover panel.
3. Release this cover panel to reveal the screws that hold the door.
4. Unscew the screws to release the door handle.
5. With the handle now off the decor panel can be removed by sliding it out.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Can't open quad cab door on 1998 dodge ram 1500
The bottom latch was rusted locked. I had to pull on bottom rod after top was already released and kick out the bottom of the door. I had to replace the bottom latch.
Nov 05, 2008 | 1998 Dodge Ram 1500 4WD
Dishwashers Logo
605 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
