Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
My toshiba 42h83 tv is dead. It won't turn on. I
My toshiba 42h83 tv is dead. It won't turn on. I checked the fuse inside and it is good. Any suggestions?
Thanks,
Chris
  • Toshiba Master
  • 1,527 Answers
Hello if you've never looked inside a tv before then you'll be wasting your time with out the right equipment it will be hard. get quote from an engineer good luck
regards
shaun
Posted on Aug 04, 2010
  • flashmaster Aug 07, 2010
    I've repaired tvs before. Was wondering if anyone had any similar problem so it would save me some time.
  • shaun taylor Aug 07, 2010
    well if you've repaired them before i would have thought you'd know the basic tests
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
My Toshiba 42H83 (2004) has double (or triple) images. Is this something that can be fixed? Is the repair some sort of lamp? If so, is that an easy fix?
This tv have a problems known as a convergence problems,it dead.The tv convergence booard the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board, must be replaced to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 18, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba Model 42H83 High Voltage Power Board is dead. Where can a new one be purchased and could a person install it themselves? thanks
possibly, the most difficult part is getting the case open usually. Toshiba parts can be souced from the Toshiba support website or a loacl dealer.
Take a pic of the board before you unplug it sop you have a reference to how it was connected. Some models have a ribbon connection in a lock, observer which way the ribbon is up as some have twists incorporated.
Aug 12, 2009 | Televison & Video
How to fix convergence problem on Toshiba TV Model 42H83
go to the site for your laptop
you can download a manual there
Dec 15, 2008 | Computers & Internet
TOSHIBA 27A40 TV
Good day.
if your remote is not responding to your tv and you were able that your remote is good, then there must be a problem with your tv.
I suggest that you have your unit be checked by a repairman. No matter how many remotes you buy, if the problem is within your tv, it will not be resolved.
chris
Mar 25, 2008 | Toshiba 27A40 27" TV
Sony kv35v36 tv no power
Good day.
It is an internal problem particularly in the power supply section. But you can try checking on the fuse. It may have been blown.
chris
Mar 22, 2008 | Sony KV-35V36 35" TV
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 rear projection tv turns on but i have no picture or sound. happened suddenly. What can troubleshoot before seeking proffessional hel.
Check all micro-fuses in power supply.If two or three are bad,a convergence circuit O/H will be necessary.Pro help usually required-chassis pull,replace convergence IC's and careful hand- soldering needed to prevent call-back.
May 21, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
134 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
