Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
I bought a new frontload washer and a used pesestal for it, but the pedestal only came with for small screws. I was told that this was all I needed but I am not convinced. Seems like there should be more to it than that.
  • Zak Steigerwald Dec 04, 2011
    what size are the 4 screws?
    President:
  • 635 Answers
There isnt anything more needed than the 4 screws.
The bottom of the front loader is designed to center itself into the pedestal so that the 4 screws are all that is needed to keep it locked down.
Posted on Jul 31, 2010
How to fix a front load washer despener?
you need to give it a good clean and unblock the holes
Jul 27, 2012 | GE White Profile Series 15 Frontload...
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Terrible vibration on washer
make sure your locknuts on your pedestal are tightened all the way up
Apr 15, 2009 | Maytag MAH8700AWM Neptune Front Load...
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Remove the shipping bolts from the back of the washer. Please see the instruction manual for more information, but there is severe vibration if you don't remove them. It seems a lot of people overlook this step.
Dec 27, 2008 | LG WM2688HWM TROMM SteamWasher
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Jan 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
165 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
