Question about Refrigerators
Something is leaking water from our freezer. We keep finding small puddles on the floor under the front wheels of the fridge. We unplugged the fridge to defrost it this morning. Don't know how long that takes, but it looks like water is leaking from 2 squares on the back wall of the freezer. It is still unplugged now.
    President:
  • 949 Answers
From the symptoms you describe the water leak is due to the defrost drain being clogged. Every 8 hours or so the refrigerator will go through an automatic defrost cycle to melt the frost from the evaporator (cooling coils). The water from this process is designed to flow down a drain into a pan below the refrigerator and evaporate from the heat of the compressor and condenser.
Foreign object or dust can build up in the drain and cause the water to flow slowly and eventually freeze up.
Unplug the power cord from the wall.
To clear this drain remove the food and shelves from the freezer section. Remove the rear panel that is behind the shelves you just removed. With this panel off you will the cooling coils. Below the coils you will see a drain trough (it might be frozen over so not visible) in the center of this area will be a hole about the size of a dime. This is the defrost drain opening.
Use hot water and a turkey baster or small tube to force the hot water down the drain until it flows freely. It may take a while and lots of water so have some towels to catch the run off.
Once it is clear you will be set to reassemble and load the food back in.
Here is a link to more details I put together on this subject
Clogged Defrost Drain.
Posted on Jul 31, 2010
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
Puddle of water on floor in front of side-by-side fridge. Fridge and freezer are cold. Drain pan is dry.
Lets make sure it is not something simple like a leaking water line behind the front kick plate. With that answered click here=> Leaking Refrigerators Just What may Be Happening Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks Sea Breeze
Sep 23, 2011 | Whirlpool Refrigerators
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Water is leaking from under GE side by side from time to time.
This _may_ be normal behaviour. When the freezer defrost element is heating, ice that melts off of the evaporator coils in the freezer will drain out of a small opening at the back of the freezer compartment and into a catch pan under the refrigerator. If that pan has other debris - cat hair, napkins, etc - the water may overflow the pan onto the floor.
Get behind the fridge, remove the bottom panel (at least that is how I can access it on my GE side-by-side), and see what you can see.
While you are back there, it is a good idea to clean the dust from the condenser coil, or use a shop vac to blow the dust from the coil.
Remember your electrical safety and unplug the fridge first, and be careful what you touch. I assume the compressor uses a large start capacitor that could still be energized even with the fridge unpluged.
Jul 28, 2009 | Maytag MSD2656G Side by Side Refrigerator
Freezer leaks into refridgerator
Your defrost drain line must be cleaned.
With a model number I could tell you where to find it.
Mar 10, 2009 | Electrolux Refrigerators
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
