Question about Sanyo Vpc-s1070w Digital Camera
Lens error When I turn the camera on it comes up Lens error 0x11110000. It worked wonderfully until I took it on vacationa and then started giving me this errror message. Can it be resolved>
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
I turn my dmc-fh27 camera and the lens won't come out. it is trying to move but it will not budge and the screen says "System Error (Zoom)".
Warning: This is only a last resort if you no longer have a warranty.
I used a variety of different methods, but here's what worked for my camera. Apparently the lens was just off the track.
1. Turn on the camera, and smack the back against the palm of your hand to get the lens to come out.
2.Hold the lens out until the "error screen" comes up.
3. Take the camera with the lens facing towards you, and use your thumbs to push on the lens.
4. Push firmly until the lens "clicks".
5. Turn off camera, then on again.
6. Hopefully cry tears of joy that you fixed it.
Jun 12, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
Well I took my camera to the beach and I think I may have got a grain of sand into my camera lens. Now it turn on and the lens comes out but not fully and it says lens error it also makes a beeping noise...
your camera will need a good air clean up in the lens mechanism its mean to be dissamble to do so
by a tech ...
hope that give you an idea
regards Allan
Sep 02, 2010 | Cameras
Lens Error!
Hi onikaassing, A very common problem in all the brands "lens error". The remedy is that you have to replace the lens block assembly. Actueally the sled motor start malfunctioning, Contact nikon service centre maybe they have the component level repair facility which can reduce the repair cost. Thanks for using fixya.
Jun 14, 2009 | Nikon Coolpix S210 Digital Camera
When the camera turns on the screen stays black and the lens will not come out.
Hello, "turn off the power and on again" its a very comman problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: A-1512-913-A LSV-1250A Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Focus error
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
May 27, 2009 | Fuji FinePix A500 Digital Camera
Lens Cover Error- Nikon CoolPix S6.
i have the same problem, but what i do is turn it on then off and then i pull on the lens a little to get it to go in all the way and then i turn it back on and it works
hope it helps
Mar 21, 2008 | Nikon COOLPIX S6 Digital Camera
Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Feb 17, 2008 | Cameras
Lens error
i didnt drop mine i turned it on and it had this problem what do i do??
Jan 26, 2008 | Nikon Coolpix L11 Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Focus error
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics (cleaning the lens, replacing the batteries, etc.), try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Feb 13, 2007 | Fuji FinePix A500 Digital Camera
Sanyo Vpc-s1070w Digital Camera Logo
75 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
