Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Status blinking yellow light. I know, the filter door loose or missing. I saw a solution that said the switch behind the door is defective. What switch ????
  • joetom27 Aug 01, 2010
    Problem solved !! Awesome
  • 10,594 Answers
There is tiny micro switch as shown in below image that is installed inside of cabinet and filter door engages it when it got fixed in its position in cabinet.
System control chip gets signal from that switch position that door is close or removed.
Hope this info will help you.
Thanks.
Posted on Jul 31, 2010
  • 1 more comment
    Thanks, I had one wire left over when I opened the door, FD. I found the switch. The switch is broken. I found a litte piece broken off that the door pin hits when in place. Now, where can I get another switch ??
    Thanks, Jay
  • Shahid Electronics
    Shahid Electronics Aug 01, 2010
    Available in Discount Merchant, click HERE and HERE to verify the required switch by clicking on thumbnail to view big image of part.
    Thanks.
    Awesome....the #2 click here is the one. Thanks !
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Filter light on
Water Filter Status Light and Filter Reset
The filter reset control allows you to restart the water filter status
tracking feature each time you replace the water filter. See "Water
Filtration System."
After changing the water filter, reset the status light. Press the
OPTIONS button to enter Options mode, then press LOCK to
initiate the reset, then press MEASURED FILL to confirm that
you want to reset the status light. When the system is reset,
the "Order" and "Replace" icons will disappear from the
display screen.
These instructions can be found in the=> GZ25FSRXYY2 User Manual . As for the dispenser and ice dispenser problem this could be related to a loose connection in the door where wiring attaches to control panel and/or where door wires go from door to cabinet also a defective pressure switch where glass is pressed to get water or ice. Can you tell me when this additional problem began?
I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | Whirlpool Refrigerators
Orange status light blinking
If its blinking yellow its the air filter cover is open or the door switch is bad. If its blinking red then the fan has stopped.
Jul 02, 2011 | Mitsubishi WD-62327 62" Rear Projection...
Just changed the lamp and the "status" light is
you must install the lamp door after lamp replacement to get the "yellow" blinking to stop. if the status is blinking red then you may be having a fan failure internal to the tv. also make sure that the side filter door is installed and secure
Dec 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubiushi wd52525. Status light keps blinking..No fan or image
If it blinks yellow the air filter cover is open or the safety switch on the door is defective. If it blinks red then one of the fans has quit working
Dec 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Yellow status light
It is doing this because the filter cover on the side of the tv has come loose, or the microswitch that senses the cover has gone bad. It is at the bottom right corner of the filter cover.
Jan 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Yellow status light blinking
tour air filter cover door is either not tight, or off, or the small switch behind it is bad. it is on the side opposite the ac plug.
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Will not turn on
check to make sure that you didnt break the kill switches on both filter and lamp door. if one is broken you can just solder the wores together or put as jumper on it somehow.
Apr 06, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
