Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
I MAY HAVE A BAD DMD CIRCUIT BOARD. CAN I REPLACE IT AND HOW?
How can i tell if my dmd board or the chip on my samsung dlp hls-6187w has gone bad
Your problem is not the DMD nor the IC. Try part number bp96-01579a for color wheel. You need to use caution when replacing. The part and flat cable are delicate. Watch a you tube video to get an idea what needs to be done.
Jun 26, 2017 | Samsung Televison & Video
I have a Samsung hlp5063w and now it has white vertical lines...is there a problem with circuit board or DMD?
hello,
Just for share, i have experience like your problem.
If your problem like picture below, thats DMD defect.
Replace it.
I hope thats will help you.
Mar 10, 2011 | Samsung DLP HL-P5663W 56" TV
I have a 2005 toshiba 56hm195 with thin lines running through it
if retrace on screen maybe the capacitor is running defective.on the screen. consult that problem to Toshiba service center.
Jun 20, 2010 | Toshiba 56HM195 56" Projection HDTV
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
Why does my samsung tv cut off by itself after 1-2 min and flash a red lamp button?
A little explanation first- this model (as do most Samsung DLP sets) will try 3 times to get the lamp lit before the microprocessor will give up and then the 3 lites on the front will blink indicating a LAMP failure. This process takes about 1 to 2 minutes. In order of probabilty, the failures are:
1) A faulty lamp and/or ballast. REPLACE LAMP AND/OR BALLAST
However, a faulty lamp and/or ballast are not the only things that will give this blink code-
2) If the color wheel has a bad bearing and turns too slow or not at all, the microprocessor WILL NOT let the lamp light, and then give a LAMP blink code. A bad color wheel will normally have some sort of abnormal sound- a low growl or high pitched whine is common. REPLACE COLOR WHEEL
3) ALSO, if the microprocessor (on the DMD board) in its color wheel rotation detection or processing fails, once again the lamp is prevented from coming on and you get a LAMP blink code. REPLACE DMD BOARD
IF THE SET EVER COMES ON WITH A PICTURE for even a fraction of a second or though it takes many tries, the lamp and ballast are good. The problem must be either the color wheel or DMD board.
Oct 26, 2009 | Samsung HLR5064W DLP Projection TV
Gray line in the middle of the screen horizontally about 10% of thscreen , let me know if you have an answer, thanks
You have a bad connection between the main board and dmd, or between the dmd chip and dmd board.
Sep 26, 2009 | InFocus ScreenPlay 5700 Multimedia...
Projector has vertical white lines
You have dirty contacts between the dmd board and the dmd chip, or the dmd chip is bad. If the dmd is bad you'll need a new light engine.
Sep 19, 2009 | InFocus SP-7205-RE Projector, Factory...
Can someone please tell me the DMD part # for a HLR6167WX/XAP?
When you replace the color wheel on certain models you must remove a jumper plug on the DMD board. There is a service bulletin that is usually included with factory replacement color wheels. If the color wheel has a whine to it that means it is probably used and came out of someone else's set. Anyhow the plug can be accessed as I recall without removing the shield of the DMD board. I know this because my first one of those gave me grief, too. Samsung changed wheels on different versions of the same model tv so it gets confusing. You should be ok though after adding/removing the two pin plastic jumper from the DMD board. The only other thing I saw cause a green picture eas the plug that goes from the DMD to the digital board can develop bad connections and can be replaced with a regular DVI type cable. Hope this helps, Russmann.
May 05, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
184 people viewed this question
Jerry Greenberg
Jerry Greenberg
