Question about Broderbund The Print Shop 21 Deluxe Full Version for PC
Making printshop 21 run properly on win 7 - Broderbund The Print Shop 21 Deluxe Full Version for PC
  • Broderbund Master
  • 5,938 Answers
You can either get Broderbund Print Shop Deluxe 2.0 which is Win7 compatible or use a virtual/dual boot computer with WinXP. (The Vista compatible version was Print Shop 23; so you are dealing with some significant changes in the OS. Thus the compatibility mode probably won't work. You can try right clicking on the installer and choose Properties and the Compatibility Tab. Check Run as Compatible with XP then right click on the installer again and choose Run as Administrator. Then do the Compatiblity mode again with the actual program.)
With Win7 Pro and Ultimate, you have an option to download and run XP mode which takes two programs that you download from Microsoft and install. This lets you run a virtual XP computer inside the Win7 computer for free. All other virtual computer programs or dual boot systems require a licensed version of XP.
I hope this helps.
Posted on Jul 31, 2010
Testimonial: "Tanks Cindy, I ordered the Printshop 2. I did not think that trying to make 21 compatible was good for my health"
  • Cindy Wells Aug 01, 2010
    You're welcome.
SOURCE:
Tip
Installing an HP G-3110 Scanner on Windows 7
Hello!
With the advent of Windows 7, some manufacturers have not created specific software to run their products properly on Win 7.
This recently happened to me, with my new G-3110 scanner.
The setup disc had no instructions/drivers for Win 7, and HP indicated to me that the driver set would not be available for another month or two.
The tip here, is as follows:
Go to the HP website, find the 'full setup' software download option for the G-3110, and download it.
After the DL is complete, right click on the icon for the file you just downloaded, and run the setup in 'Compatibility Mode'. You may or may not have choices. At this moment, Vista and XP both will be viable choices for the install in the Compatibility Mode, for Win 7...
Hope this helps some people out, until HP releases the proper software for Windows 7.
Addendum to this tip, written on January 21, 2010...
HP has FINALLY added Windows 7 drivers and software to their site., You can now download the software for the HP G-3110 scanner online. Go to www.hp..com, and choose the Download drop down box; input the G-3110 scanner and performa and run the download.
If this helps anyone, a click on the VERY HELPFUL icon would be appreciated!!! Thanks! .
on Dec 03, 2009 | Office Equipment & Supplies
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
New computer has Windows 7. What version works on Windows 7?
Older programs can usually be run in Windows 7 using compatibility mode.
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Mar 04, 2011 | Broderbund PrintShop Signature Greetings...
I've installed Printshop 21 on my new computer. I
Go to Control Panel,, Click Install New Hardware,, it will search for anything NEW, then ask you if you want it to automatically install the Drivers ! Click YES !
Nov 14, 2017 | Broderbund Print Shop® 21 Pro Publisher...
I am unable to get my printshop propublisher deluxe 21 to run on windows 7.
Try Installing as Administrator, BOTH installing and "Run" the .exe as Administrator. Also try setting again both install .exe and the run .exe, in "Compatibility Mode" for XP SP2. to do this right click, .exe and select properties, then choose compatibility, mode and set there. If Win 7 on 64bit, remember to turn OFF digital driver signing, press F8 at boot time, and select at bottom of list.
Mar 24, 2010 | Computers & Internet
Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
784 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
