Question about Mitsubishi WD-65733 65" HDTV
Tv shutdown I recently replaced the lamp for my tv and it still shuts down daily giving me an amber light with a blinking green light. I power it down...wait a few minutes and turn it back on. The amber light remains on and the green light comes on, I have sound with no picture. Then I power it down for a few minutes wait until the amber light goes off then I can turn it back on with picture and sound working fine. This happens once a day at least. Any suggestions would be helpful. My tv model is a Mitsubishi WD-65733.
  • Mitsubishi Master
  • 2,005 Answers
Check your lamp door interlock switch.
Posted on Jul 31, 2010
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
What does hdmi is blocked mean
Hello!
HDMI blocked could mean, that one or more HDMI inputs are turned off. In WD- series DLP TVs it's possible to disable one or more inputs, which are not to be in use, to speed up signal source switching. Most of modern sets are constantly monitoring inputs and automatically recognizing "plug"n"play" signals. blocking any input would not cause TV to shut down.
Yellow(amber) light means: lamp door interlock switch is off or malfunction. green blinking: set is initializing, about to begin normal operation. So: quite possible that lamp has been replaced incorrectly or door is not tight intermittently. Last possible issue: door's interlock switch is bad. Take lamp door off and you will find the switch with blue lever on the left side of the door inside plastic compartment. Push it with your "pinky" or pencil carefully, then ask someone to turn set on. Make sure, yellow light is off, before do so. If set starts normally, observe lamp's activity: it should stay on and getting brighter, while you holding switch. If lamp stops working, while there is no "amber" light, then TV shuts off, red blinks, lamp is bad. I just had to replace lamp twice, due to defective batch of lamps with housing. 3rd time I replaced bare bulb and it solved the problem. But there was no "amber" issue!
good luck,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
What is the solution to the blinking green light and welcome screen then tv shuts itself off
I recently had this problem on my model as well, though it was lessthan a year old. The method that worked for me is to update thefirmware of the TV itself; you can download the new software, with complete instructions on how to update your TV at http://support.mitsubishi-tv.com/documents/WD-60C9
After doing this, my set started working again.
Do not replace your lamp. the light will blink red for a bad lamp, not green.
Jun 18, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Mitsubishi WD-65733 65" HDTV Logo
471 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
