Question about Intex 2500 Above Ground Swimming Pool Filter Water Pump ()
The pool is still cloudy even with all chemicals balanced and a clean filter? I tried the clarifier stuff too and its still like chalky. How can i get it crystal clean?
  • Intex Master
  • 8,404 Answers
Follow these steps ... let the CL go to zero ... add a sequestering agent to get the metal out. Follow container instructions ... run the filter 24/7 (deferring to the instructions on the sequestering agent.) When the metal is out, get your calcium to 300 ppm, get your alk to 100, get your cyanuratic acid to 70 - 90 ppm, get your pH to 7.2/7.4 and introduce 2 to 4 ppm of CL. Do this in this order over the course of 2 days. Dont dump all this stuff in at once and expect good results.
If Cal is more than 300 ppm, dump some water and add new. What is the Cal level in your fill water? Be aware of that number as you adjust.
Use Sodium Bi Carb to increase your Alk
Use Sodium Carb to increase your pH
Use dry or liquid acid to reduce Alk and/or pH as necessary
Get the Alk set first before you try to adj the pH.
The Cyanuric acid will protect your CL from the sun.
You cannot run your filter too long! Backweash only when the pressure raises 10 lbs from the new fresh startup pressure. Doing so before is wasteful of chemical and defeats the filter process.
If you are using salt, get the water as I said before you turn on the salt cell. Add salt per instructions on the bag. Use pool/food grade salt only!
I hope you find these comments helpful.
Thanks for your interest in FixYa.com
Posted on Aug 01, 2010
Pool cloudy with yellow powder salt system
yellow is mustard algea super shock then brush pool then clean filters and repeat if needed keep PH about 7.2 alkalinity about 100 you should be ok
Jun 12, 2014 | Pool & Spa
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
Hayward vari-flow valve sp714 cloudy water
Otherwise chemistry fine?
whenever someone is vague about chemistry residual readings, but provide a pH reading, I'm always Leary.
  • bring pH up to 7.6
  • Balance Total Alkalinity at 120 ppm
  • Bring Hardness to at least 200 ppm
  • Keep Chlorine level at least 3.0 All the time
  • ISO Cyaniric acid / stabilizer at least 30, not exceeding 80 ppm
  • Use a Natural Clarifier weekly - rate = 1 ozs per 5000 gallons
  • Use Algaecide (not from Kmart!) weekly
  • Clean filter whenever pressure approaches 8# over starting
  • Filter for at least 1 turnover per day. This is usually 8 hours in most regions
Follow this, should be good
May 25, 2012 | Hayward SAND FILTER, PRO SERIES
Have saltwater system 6500 gallon pool (18x48) opened pool with 4 bags pool salt, 1 bag stabilizer, 1 bottle algeaguard. Ran pump to dissolve salt first then turned on saltwater system, added algeaguard,...
Thank you for posting your question here on Fixya.com.
You need to be able to test at least chlorine, salinity, ph, alkalinity, and stabilizer. The best way is using test strips. If you have a sample of water tested at a pool supply store that will work too but frequent transportation is more costly than strips. The salinity should be about 3000 ppm, Chlorine should be between 2 and 4 ppm, alkalinity should be between and 80 and 140 ppm and the stabilizer should be between 30 and 50 ppm. Some say up to 100 ppm. Unfortunately higher stabilizer reduces the chlorine's ability to kill algae, etc. When the water becomes cloudy it is likely low on chlorine and is about to turn green. If the test shows low chlorine level then I would add shock to 10 ppm chlorine. If the filter system is working correctly then it should clear up fairly soon. I would not let anyone swim until the chlorine is between 2 and 4 ppm and you can clearly see the pool bottom.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! Thank you.
Aug 28, 2011 | Intex Pool & Spa
We have a hayward sand filter model sp 711 13 for our vinyl lined pool. We are having alot of trouble getting the pool to clear up. When we opened it for the season, it cleared up great and was running...
How long is it since the sand in the filter was changed? How long has it been installed? If the water is clean but cloudy, get some kind of flocculant from your pool supplier. Follow the instructions carefully as your pool will need to be bavkwashed on a frequent basis.
Regards alshipman@gmail.com
Jun 27, 2011 | Hayward Pro Series Sand Filter -36" Tank
My pool is cloudy I have a 16'x48" the ph level is 8.0 the copper test is 0 the free chlorine[ppm] 0.2the alkalinity is right what should i do
How long has it been since you cleaned the cartridge in the filter? If it's been a while, I'd recommend cleaning it thoroughly with a filter cleaner (degreaser). This will help to filter out any small particles that can cause cloudiness. I'd also recommend that you increase the salt production on your salt system. The normal range for chlorine is 1-3 ppm. You're too low at 0.2. If all of these things are done and the pool is still cloudy, I would add a clarifier. FYI: too much is not better when adding clarifier!
Jun 16, 2011 | Intex Automatic Salt Water System for ...
Water comeing out cloudy and makeing suds in pool
There could be a few things causing these problems. How old is the sand in the filter? Filter sand looses its filtering ability after 3-5 years and needs to be replaced. If the sand needs to be replaced, make sure you get actual pool filter sand. A lot of big box and home improvement stores sell play sand as filter sand. That will cause your pool to stay cloudy and never clear up. If the sand is less that 3-5 years old, you may need to clean it with a liquid filter cleaner that is poured through the skimmer. This works quite well!
Another issue causing the cloudiness and bubbles could be the type of chemicals you are using. I know that shock from big box and home improvement stores cause the water to be cloudy. Algaecides from these stores also cause foaming.
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
Last fall when I closed my pool, I noticed a fair amount of sand exited out the bottom of the sand filter drain. In previous years, only water drained from this location. I have now opened the pool and am...
You may have to change the sand if you never have. Or if it's not too bad you can "clean" it. When you removed the plug form the pool, there should actually be two parts. This first part threads directly into the filter, and has a screen on it to hold back the sand. The second one is the plug. This is the only part you should remove, except when changing sand etc. Even if the pool filter is working you can have cloudy water. See you pool supply, and try a floc to help settle dissolved solids in your pool. You add this, run the pump awhile to mix, turn pump off overnight, and then vacuum everything next day. Then turn pump back on.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter not filtering small particles
You probably have too big of pump. It is pushing the finer stuff right back into pool. Try adding a clarifier. Don't backwash either until the pressure goes up.
Jul 30, 2009 | Hayward Pro Series 18" Above Ground Pool...
Intex 2500 Above Ground Swimming Pool Filter Water Pump () Logo
204 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
