Question about Makita Drills
How do i remove the chuck from a Makita 8391D
How do i remove the chuck from a Makita 8391D cordless drill ?
    Sergeant:
  • 313 Answers
I think you will find that if you open the chuck fully you will see a cross head screw inside the chuck which you need to undo before removing the chuck. this secure the chuck from unscrewing while being used in reverse to undo screws. Once this screw is out a spanner is used at the base of the chuck to unscrew it from the shaft. this may need a short sharpe shock to get it to move.
Posted on Jul 31, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Makita sometimes uses a torx or flat head screw .First open the chuck all the way and look inside to see if there is one if so it will have left hand threads so turn the screw clockwise.most drill chucks have a torx type hole to put your torx wrench into.If you don't have one tighten the chuck around a piece of round or square metal then insert into vise.Chuck threads are standard threads so **** hard and it should come off.I have allways used my impact wrench with a # 45 torx
Posted on Oct 15, 2010
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
How do i remove the drill bit from a Makita 8391d cordless drill
Put the clutch on a high number, put the reverse on, hold the chuck tightly, lightly press the triger. If it does not come undone, make the clutch tighter (loer number).
Jul 17, 2010 | Hand Tools
Hi i broke the chuck on my 1/2 makita cordless
Put the biggest hex key you have in the chuck and tighten it then hit it clockwise with the spindle lock engaged a couple of times. The screw in the chuck will then undo clockwise and the chuck can be undone after by putting the allen key back in and unscrewing it anti-clockwise maybe with a light tap from a mallet.
Hope this helps
Jon
Jul 01, 2010 | Makita 6349DWDE 18-Volt Ni-MH 1/2-Inch...
How do I remove the drill chuck from my makita cordless drill? I have removed the screw.
Try tightening short end of an allen key/wrench, in the chuck, and give it a good smack counterclockwise.
Apr 14, 2010 | Makita Drills
How do I take the chuck assy. off a Makita 12 volt drill driver?
open chuck up all the way, and look down inside for a screw at bottom that needs to be removed, then twist it off.
Apr 11, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How to remove the chuck on a makita or other hand held electric cordless drill
usually with a special tool to hole the drive, if you look at the back, if the chuck, where the shaft mates you will see it has two flats or a profile on it, you make get a tool that can grip that and twist the chuck. If it hasn't you have to somehow jam the Motor, or the shaft, and again twist.
Mar 25, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do you remove the chuck on a 18volt makita drill driver
there is a flat head screw in the center of the keyless drill chuck counter clocwise to remove.
Nov 28, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Drills Logo
2,389 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
