Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Control panel not working
I have a whirlpool duet dryer and the control panel is not working. I open dryer and the inside light comes on but have nothing at the control panel. Is there a reset on the dryer.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To reset the dryer you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. If still the issue is not resolved then unfortunately you'll have to replace the control panel. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Whirlpool duet dryer doesn't work after power surge
Hello, well that sounds a fuse problem, you can try check inside, be shore you unplug the power socket before you do it, if the inside fuse is ok ,so the control board is damage and needs to be replaced, and don't think it worth .
Thanks
Nov 22, 2013 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Oct 22, 2013 | Dryers
I have a Whirlpool Duet Dryer. It turns on sensor light is on but will not run.
To get to it unplug the machine. Remove the top. Push in on the release tabs on the inside of the control and remove it. Unplug the control quick connect and set it to the side. Get the brace off. Get the control board panel out yer way. Open the door and remove the screws. Take the bottom panel off and the front panel then the drum out. Give it a good hoovering all over and replace the thermal fuse.
DUET DRYER MANUAL
Wanna see a video? This video shows how to replace a thermister. Next to it is that thare thermal fuse.
Rate it or hate it: ece6c0d.jpg
Jul 28, 2010 | Dryers
Control Panel in my whirlpool duet dryer model #GEW9250PWO will come on & the dryer will not work at all. Unplugged dryer and plugged back up still doesn't come on. The light within the drum is on when...
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Jul 14, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I...
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I plug it back in the control lock light come back on. Whirlpool Duet gew9250plg
Aug 05, 2009 | Whirlpool GEW9250 Electric Dryer
Duet dryer ygew9200ll1 will not turn on
make sure the door connecting also theres a capacitor inside these can stop your dryer working
goodluck
shaun
Jan 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer is plugged in & light comes on, but won't work
If your control panel display isn't working, a longer cord and more flexible hose won't fix it. You either have a control panel that has failed, or the wire harness that leads from the main control board to the control panel has an open or short, or has come loose. In addition, flexible dryer hoses (like the plastic ones) are not recommended because they tear easily, crimp or crush easily, and mice love to chew right through them to find a place to nest. It is highly recommended to stay with a semi-rigid duct hose, because they resist crushing, crimping and clogging. I hope this info helps. Let me know if you need further assistance.
Aug 15, 2007 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
491 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
