Pioneer vsx-9900s Hello I flipped you a fixya. can you help with some test points I could not find a service manual fo rthis unit anywhere. I love this amp and wan to fix it.
  • 1,512 Answers
Hey man,... no worries.
Were any fuses blown? Check this first and foremost before you do anything else. If there were blown fuses, you then (if you are familiar with how), need to check the output stages for shorts. NOT generally to ground as you have suggested.... but more between the center and outside pins (collector emitter short we are looking for here) To check the output transistors properly, you need to unsolder leg and check each of the output transistors junctions base emitter, and base collector, and also collector emitter for any leakage. Once you find the offending channel(normally there is only one), you need to then carefully check the driver transistors also. Pay attention to low value resistors about the output stages, small signal and zener diodes and if they are there, any power diodes. If you are unsure of the condition of a part, then replace it to be sure :)
Hit me back and let me know how you go.
regards
Graeme
Posted on Apr 25, 2008
  • Graeme Ross
    Graeme Ross May 05, 2008
    How did you get on mate? :) Any luck. Still here to help you.
Where can i find user manual for pioneer remote control?
You can't get it from anywhere; except the authorized service center for pioneer. If you have any doubt, there is some experts in FixYa. They have recently started a site to help you like people; wit some "EXPERTS" they claim.
But; do not think that service for none.
You have to pay for it in advance.
If you're not satisfied, let it be. You won't get the money you have paid.
Just pay it, and understand the expertness of that persons; that FixYa claims as "Experts" in this field.
This is the site.
https://www.6ya.com/
Good Luck.
Nov 05, 2015 | Pioneer AXD7615 Remote Control...
I have a pioneer vsx-9900s it has high low speaker impedance switch all my speakers are 8omhs what do i set the switch to low or high ?
This is fairly variable depending on such factors as the sensitivity rating of your speakers; but as a rule of thumb just put the switch at low and you should be fine.
Dec 17, 2014 | Pioneer Audio Players & Recorders
I have a Pioneer VSX-D412 reciever, and connot get my b channel to work. Only my A channel works, and I'd like to get both or all 5.1 working. And no I don't have the manual for the system.
In case you didn't see this on the other post, it is not the function of unpaid Fixya Experts to do the web searches for or read the manuals to those who can do it themselves. Most questions submitted to us would find answers immediately if they were typed directly into a search engine.
If you don't have the manual I recommend you get it. There may be other questions. A search for "Pioneer VSX-D412 manual" finds it.
What sources fail. How is it with test tones? have you isolated (swapped) the speakers?
Here is the service manual if you should ever need it. http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-D412_RRV2727.pdf
Aug 04, 2011 | Pioneer VSX-D412 Receiver
Hello, i have a pioneer vsx-d508 receiver, and i cant get any sound from it the thing works but no sound i tried everything the manual said to try but still nothing ,,can someone help me or point me in the...
Is this new or was it working for a while and then failed? Does it otherwise look 'normal'?
Use FM as the source to test because it doesn't have any way to miswire it. Turn the volume to something less than midpoint so you don't blow the speakers when the aha moment arrives.
Look for an unwanted Tape Monitor or Mute activated. Speakers enabled. FM selected for t his test.
Jan 17, 2011 | Pioneer VSX-D508
I have a pioneer vsx-9900s- was running it hard for New Year's and at the end of the night it started to smell and then the sound stopped dead. The front panel and all controls work, but no second click-...
If the thing smells you shouldn't need any test equipment apart from your eyes and nose. That should lead you to something burnt up! Unlikely you will encounter any high voltage parts.
Jan 02, 2011 | Pioneer Audio Players & Recorders
Pioneer VSX-45TX turning itself off
check all speakers and wire not short... you can try open each speaker testing....
Nov 12, 2009 | Pioneer VSX-45TX 7.1 Channels Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Vsx-9900s
Hi angelo40
The amp sounds like it has a primary power supply failure and/or may be in protection mode. First, I would check for any blown fuses, replace any you fint with exactly the same type and rating. I can advise you here if you are not sure. If the unit blows a fuse after replace any failed ones, then there is a short circuit that you will have to trace out in the unit. DONT KEEP REPLACEING A BLOWING FUSE You generally are just doing more damage to the amp.
If all the fuses are OK and you are savvy with electronics and soldering, you could open it right inspect for these problems., and you have a multimeter, do some powersupply voltage checks, also check for that the main transformer is ok. Resolder any dry joints you find.
It may also (and or) have a problem in the output stages. Running it hard may have produced some dry solder joints, or blown a transistor in the output array. Happy to advise you further, just ask :)
regards
Graeme
Apr 20, 2008 | Audio Players & Recorders
Pioneer VSX-D498
Sounds like the on board computer (micro-processor) is waiting for a process to happen and when it does not happen then the unit times out and shuts off. Could be a mechanical or electrical process. Good luck.
Mar 23, 2007 | Pioneer VSX-D498 Receiver
Vsx-108 preset resetting
I too have the issue. Any luck in your resolve? I am checking with a service center but would love to resolve it myself.
Dec 06, 2006 | Pioneer VSX-108
384 people viewed this question
 Grubhead
Grubhead
