I am using a Philips SRU3003WM/17 Universal Remote with my Sylvania TV Model number 64119E. When programming the remote some strange numbers appeared on the screen and now I cannot get them off. The screen is frozen and there is no sound or anything. The only way I turn it off is to unplug it. I cannot seem to figure out what to push to get it to the correct mode. The owner's manual is not very good. need help.
  • carolmikita Jul 31, 2010
    I am sorry I forgot some information. the remote was working perfectly. I accidentally hit the guide button and the picture froze, this happened once before. A friend was over and got it working, the first time, but wouldn't tell me how. Now two days ago, I did it again.
    You can't change the channel, there is no sound, you can't shut it off, unless you unplug it, there are numbers and letter at the top of the screen. The remote is still working for my other tv in the bedroom, I know the codes. I have been using this remote for three months. I tried what was in the manual, like pressing quit, nothing works. I am disabled, on a small disability check, the tv and computer are all I have. Can someone please help. carol ann mikita thanks
  • Televison & ... Master
  • 2,005 Answers
I'm afraid that if you do not have your original remote control you will not be able to fix this easily.
what has happened is your tv's service mode has been activated by the other remote control. this is the hidden mode we tv repair people use to make internal adjustments
to your tv. if you can get athe proper remote for your set pressing "exit" should return your tv to correct function again but, it must be the exact remote model for your set.
Posted on Jul 31, 2010
  • 3,230 Answers
Well your Philips universal remote control comes with a list of codes for devices by brand name.
Find the first code for the brand name and type of device you wish to program. Turn all of your devices off, and then manually turn on the device you want to program.
Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV.Release it immediately and make sure the indicator light is illuminated. Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button. If the device responds, you have successfully programmed your Philips universal remote. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
If your TV code is not listed on the manual then you can use the Remote Using Code Search Option -
Your Philips universal remote has a built-in code search feature that will find the correct code for your device. This process may take longer than using direct code entry, but can be helpful if you do not have access to the code list or if the brand for your device is not listed.
Make sure all of your devices are turned off, and then manually turn on the first device. Press the Code Search button and hold it down until the red indicator light stays illuminated. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV button.  Release it immediately and make sure the indicator light is illuminated. Press either the Channel button until the device responds. You may have to press the button up to 300 times. Each time you press the button, the Philips universal remote tries a new code. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
I thing you wrongly do the second option that creates the problem. No issue, if your tv code not listed on the manuals then you can go with the second (code search) solution. Please post comments for further help or information.........
Good Luck!!
Thanks
I have a Magnavox SDTV converter box. It did not come with a remote because it was a display model at Walmart. It is plugged in, but will not come on. I have a Philips Universal remote, model #...
Start by turning on your Magnavox converter box. The switch is on the right side. Turn on your TV. If the box has been connected correctly to your TV, you may see something ...BUT you cannot perform setup or any other important functions without the Magnavox remote. A universal remote, unless it specifically includes Magnavox converter control capability, will not work
Dec 02, 2012 | Philips Televison & Video
I need the codes for Philips remote sru5101/17 for an emerson Tv
Codes to check are: 0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Oct 21, 2012 | Philips SRU3003WM/17 Universal Remote...
I need the code list from universal remote control (Philips) to RCA tv The brand of the universal remote control is Philips and model SRU3003WM/17
The list of codes can be found here.
If your TV is newer, I would start at the end of the list and work backwards. There are a lot of RCA codes in this list, so it may take a little while to find the right one.
Jan 13, 2011 | Philips Televison & Video
Need codes for a universal Philips Magnavox control for my insignia tv.
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 12, 2010 | Philips Magnavox Learning Universal Remote
Need codes for a philips SRU3003WM/17 Universal remote
does anyone have the manual for Philips universal t.v. remote..I lost my manual. and need some help.Thank you in advance.Jeanne
Jan 25, 2010 | Philips PM3S Remote Control
CODE LIST FOR SRU3003WM/17 FOR TOSHIBA TV
these are the codes for toshiba try all to find best one
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
Jul 15, 2009 | Philips 4-Device Big Button Universal...
I have no ''tv/catv'' button on my Philips universal remote
You can go here to see if you can get a new factory remote
TV Parts Universal TV Stands DLP Chips ShopJimmy or you can get a Harmony remote that will never go obsolete no matter how many times you change Tv's in the future or add components to your system
Oct 12, 2017 | Philips Magnavox Learning Universal Remote
Need codes
i have a sylvania tv with a ge universal remote control
Oct 02, 2008 | Televison & Video
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Model number of the remote would have been nice, but look here:
http://www.xdiv.com/remotes/
Geno
Jan 23, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
