Question about Sharp Notevision XG-C50X Multimedia Projector
SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
    President:
  • 567 Answers
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Posted on Jul 31, 2010
    • Hilton Bristol Jul 31, 2010
      Sound, But No Picture
    • If you have sound but no picture, verify that all the cables are tight. Set "Bright" at minimum.
    • Color/Picture Issues
    • If the color is not good, meaning that it is faded, too bright (whitish) or murky, make sure the picture adjustments are correct. Check to make sure that the RGB/component setting is correct. Check the Video Input. You can try multiple options with these settings and see what works. If the picture is blurred, adjust the focus. If you are using a computer as the image source, you can perform various Fine Sync Adjustments on the projector. Both "Clock" and the "Phase" can be adjusted.
    • Picture, But No Sound
    • Check the volume, the cables and the audio output cable on the computer.
    • Dark Picture
    • If the lamp indicator is red, replace the lamp.
    Wired Remote Control Doesn't Work
  • Verify that the cable is plugged in. Make sure that there are not two or more projectors in the room and that you are trying to operate the switched-off projector.
  • Other Considerations
  • Be careful how much you tilt projectors. The Sharp PGA20X can be tilted up to 12 degrees of horizontal. Avoid extreme temperature. Do not block the vents and do not switch the projector off while the fan is running and the projector is cooling down. Transport the projector carefully. A rough impact can damage it, especially if the bulb is hot.
    There is a large green spot on the screen. Really noticeable when on a dark screen.
    either the Green LCD Panel is shot, and/or the Green Polarizer Glass. unfortunately the only way to fix it is to replaced the whole Prism assembly.
    May 26, 2011 | Sharp Notevision XG-C50X Multimedia...
    I'm looking for the service manual for a Sharp XG-C50X
    To my knowledge this manual is available on paper only. What is the problem you are trying to solve? Perhaps we can help you to solve it.
    Dan
    Jan 04, 2010 | Sharp Notevision XG-C50X Multimedia...
    Sharp XG-C50X Notevision. Doesn't get past "warming up"
    it seems that the powersupply is failed
    Have a nice day!
    We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
    motherboard, powersupply ... with high quality and competitive price.
    Jerry
    Lampdeng Limited
    Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
    Sharp Xg-50X projector won't turn on. Replacement light not on.
    I pulled the projection bulb and did a continuity check on the filiment. It was open. I ordered a new bulb.
    Thanks.
    Feb 14, 2009 | Sharp Notevision XG-C50X Multimedia...
    User manual
    Solution for Sharp projector
    with the function button on the laptop and the lcd button, F5 for toshiba, the screen will display both sides. if not then give the details of ur laptop.
    Dec 11, 2008 | Sharp Notevision XG-C50X Multimedia...
    Sharp XG-C50X
    Did you reset the lamp hours?
    Aug 21, 2008 | Sharp Notevision XG-C50X Multimedia...
    Changing settings
    Hi cajun51man
    If you go into the User Menu of the Projector look for a subfolder that reads either Flip Image or Mirror.
    Scroll down to it and scroll left or right - this will switch between the image features.
    May 26, 2008 | Sharp Notevision XG-C50X Multimedia...
    Sharp Notevision XG-C50X Multimedia Projector Logo
    215 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
