Question about Husqvarna Chain Saw 20" Bar
How to replace gas trigger switch on
How to replace gas trigger switch on husqvarna 340 do i have to tear the saw complete to put on
    President:
  • 2,702 Answers
No you dont,,,all you need to do is undo a fuw screws in the handel
Posted on Jul 31, 2010
How to put a tension screw on a husqvarna 340
The one tensions from the front between the guide bar and bumper bar, is a screw fit.
Ive added the picture from the IPL and highlighted the parts. Hope it is of some help.
Apr 13, 2013 | Husqvarna Chain Saw 20" Bar
I took my husqvarna 340 apart and need a diagram to put it back together
I'm having difficult time aligning the throttle arm any secreats
May 17, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the gas to oil mixture for the Husqvarna 340 Chainsaw
The fuel to oil ratio is 50:1. Be sure to use a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Premix in it's own container with fresh fuel and be sure to shake the container thoroughly just before you fill the tank each time to prevent oil starvation. Hope this helps!
Dec 22, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Gas trigger jams and does not depress fully on a husqvarna 345. The unit is 9yrs. old.
Check for wear on the plastic end of the throttle push rod, if so it tends to catch where it comes out of the fuel tank, replace if worn.
Oct 17, 2010 | Husqvarna Chain Saw 18" 450 Model...
Cannot start husq 340 have spark but no combustion even if put gas in spark plug hole. have new spark plug
The engine may be flooded--take the plug out, turn the saw upside down, and pull the starter rapidly a few times with the throttle full on. If flooded, a fuel spray will likely come out of the plug hole. Make sure the ignition is OFF when doing this--you don't need a fuel fire! Is the spark at the plug blue and snappy (plug gap set to 0.020")? Replace the plug and see if it will run. Make sure the air filter is clean. Hope this helps!
Oct 16, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Replacing bar on husqvarna 340 saw. Appears to be a spring attached to guard that will not allow the guard to slide off. Does spring have a certain amount of tension and how is it removed so guard will...
Sounds like the blade brake is engaged. You should be able to pull the blade brake handle, located on top of the saw, in front of the top handle, back towards the handle to disengage it. You can find replacement bars, chains & sprockets for your saw at Partsbuggy.com.
Sep 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 350 quits under load
had the same problem the other day with my model 55 rancher found the pin missing that
holds the handle to the trigger mechanism once i found the pin put it back in the handle the unit works fine. the pin is about 1/8 X11/4 " long.
Apr 22, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
143 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
