Question about Midland LXT310 2-Way Radio
Lxt310 midland 2 way radio, display always shows "rx",
Appears to be stuck in the message receive mode, static sound always heard
  • Radiojunkie Sep 02, 2010
    Have you tried a fresh set of alkaline batteries?
Benimur
  • 6966 Answers
SOURCE: GMR1035-2
The RX symbol and static noise would only appear if the squelch is down or if you are receiving something from a transmitter.
Receiving something could mean either an intelligent radio transmission from another comparable unit or this could also be spillover signals from adjacent radio transmitters strong enough to override the squelch settings normally called "splatter". At times, electronic devices could cause this effect such as RFI (radio frequency interference) from units such as a personal computer.
It is also possible that your Monitor Mode is "ON", turning it OFF would possibly resolve the issue To turn OFF monitor mode:Press the vol/mon UP or DOWN key. The RX icon will stop blinking and disappears.
In some cases, a component failure would cause this problem. Your GMR1035-2 uses an Automatic Squelch Feature, this would mean the use of a FM Discriminator Chip for Squelch Control. Most manufacturers uses an MC3357P IC chip for this purpose. This of course would require opening the unit, desoldering the suspected component and solder in a replacement. This would further require that you be familiar with electronic components, circuitry, DVM and a low wattage soldering iron. Should you not be comfortable doing this, perhaps your best bet would be to seek the services of a qualified technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 10, 2007
eradiostore
  • 1654 Answers
SOURCE: constant static
You have one of three issues: 1) You are close to another device transmitting on your frequency, 2) Your radio has a problem and needs service, or 3) You have a low, bad or defective battery.
What you can do:
--Try the radio at a different location to see if the problem is only at a certain location. This will tell you if it is simply interference by another device.
-- Check your antenna for damage, replace if necessary.
--Try the radio with another known good battery and see if the problem goes away.
--If you don't have another battery, try turning it on when in the charging cradle. (NOTE: Do not press the PTT while the radio is on the charger. This can damage your radio. The radio should always be turned off when charging, unless running a simple test such as this one.)
If these do not solve the problem, your radio needs serviced.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: Lost my instructions for Midland X-Tra Talk LXT310
Here you can download the manual for your radios. http://www.midlandradio.com/Resource_/OwnerManual/53/LXT410.pdf Hope this helps.
Posted on Jun 13, 2009
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
SOURCE: Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Posted on Apr 15, 2010
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
How do I adjust squelch. Squelch is locked on
I suspect you have it in the continuous monitor mode so follow the directions for getting back into the automatic squelch mode.
AUTOMATIC SQUELCH: The FRS is equipped with an automatic squelch circuitry filtering out weak transmission and unwanted noise, usually caused by terrain conditions.
MONITOR:
- This feature turns off the automatic squelch feature, either momentarily or continuously. It helps in receiving signals to its maximum range, but may pick up static signals, too.
Momentary monitor:
- Press the MON button; the monitor symbol will appear.
- Release the button to restore the automatic squelch.
Continuous monitor:
- Press the MON button for more than 2 seconds until a beep sound is heard. The monitor symbol will appear.
- To restore the automatic squelch, press and release the MON button again.
NOTE: You cannot transmit when the Monitor feature is activated.
This comes from the manual I found on-line at:
http://www.michaelknows.com/electronics/walkie-talkie-manual/
Oct 26, 2013 | BellSouth 1011 (14 Channels) 2-Way Radio
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
Whenever i turn off the mains, i get a Demontration message after power on.
From the manual:
Demonstration Mode
DISPLAY THANK YOU”
Press ?/1 to turn the receiver off while the above message
To view the demonstration
Hold down SET UP and press ?/1 to turn on the power.
Notes
• Running the demonstration will clear the receiver’s
memory. For details on what will be cleared, see
“Clearing the receiver's memory” on page 15.
• There will be no sound when the demonstration mode is
activated.
and...
Note: If the AC power cord is disconnected for about two weeks, the receiver’s entire memory will be cleared and the demonstration will start.
Mar 17, 2010 | Sony STR-DE445 Receiver
I got a cobra 29classic cb, little hours. i have
Set the squelch and knob to full counter-clockwise position. Turn the volume up to the 1/2 way point. Disconnect the external speaker plug from the jack. Disconnect any PA speaker plug from jack. Static / voices should be heard from internal speaker. If not disconnect the mic. Static / voices should be heard. If not, tune a different channel, sound should be heard. if not, look for indication of the radio stuck in transmit mode. If in transmit, there will be no sound until you can stop transmitting (hopefully while connected to a 50 ohm dummy load or suitable antenna - otherwise the final transistors may be blown). Reconnect accessories to determine problem component.
Mar 12, 2010 | Radio Communications
No voice to Garmin Nuvi 660
In case it is a software problem try this and see if it will fix it......follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Jan 17, 2009 | Garmin Nuvi 660 GPS Receiver
No message recorded. Static when in use.
It sounds like you have damage to an internal component of your phone.
HERE is a link to the manual, if needed.
Jan 23, 2008 | AT&T ATT-1855 Corded Phone
Lots of static heard during use of this phone.
Time for a new phone. Most likely there are some bad solder connections and they could be anywhere. A 2 year old battery should not cause such severe problems so I'd spend the money on a new phone before a new battery.
Jun 27, 2007 | Motorola Mobility MA580 5.8GHz Digital...
Midland LXT310 2-Way Radio Logo
451 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
