Question about Miele S514 Solaris Turbo Plus Vacuum
Pluged into 110 vac, but no power to the motor.
MIELE Solaris Turbo Plus - S 514
3 Suggested Answers
SOURCE: Miele Solaris Electro Plus will not turn on
I was using my Miele Solaris Turbo plus to **** the air off the Space Bag. Now I have the red indicator on and the vacuum cleaner won't turn on. Please help. This is my favorite vacuum cleaner!
Posted on May 31, 2008
  • 95 Answers
SOURCE: miele solaris turbo plus S514 will not start in live outlet
The reason why the vacuum will not start is because of the cord winder. They are pretty tricky to repair yourself. A service center could probably fix it for about $50.00. It has been a while since I have worked on one of these but I think the screws are under the switch and maybe the filter.
Posted on Jan 20, 2009
What is the speed range for moving our Miele Solaris S 514 horizontally over the carpet for optimum weekly dust removal?
When the dust is gone the speed is correct . You should use a back and forth movement so the rug fibers contact the machine efficiently. There is no perfect speed since the amount of dust in a carpet is not uniform. Hi traffic areas will require more time spent removing dirt than an area close to the wall here there is no foot traffic.
Aug 14, 2016 | Miele S514 Solaris Electro Plus Vacuum
Miele S514 Turbo red light on. Dismantled and cleaned. Motor checked and no resistance. Circuit board? Can it be be replaced or by passed?
If there is a circuit board between the cord and the motor it is certainly replaceable. Unfortunately my suppliers don't have schematics for the Miele models. You might try the Miele website, if there is one, or call your local repair shop to see if they service them. Sorry I can't be more help.
Jun 14, 2014 | Miele S514 Solaris Turbo Plus Vacuum
Miele turbo s514 power
If it has no suction take bottom peice off take out brush roll then run clothes hanger through dust channel to clear any blockage if none there its in your hose
Mar 27, 2013 | Miele S514 Solaris Turbo Plus Vacuum
My turbo plus does not turn on when plugged in. This is the first time this has happened. Any suggestions?
Check the power switch, plug cord and vacuum wiring. A open circuit will cause that and you need a continuity tester to test it. Once you find the trouble part, replace it with the same size and rating. A dent or vent wire will cause not to flow the current and voltage so check it.
Thanks for asking.
Jul 13, 2011 | Miele S514 Solaris Turbo Plus Vacuum
I have a Miele turbo plus solaris and the red warning light is on. This prevents the vacuum from working. I have changed the bag so I am not sure what to do?
I had this problem with a different model. It's caused by a thermal cutout switch in the motor. My problem was a result of a filter being removed and the bag not seated correctly, hence dirt got into the motor and clogged the turbine, reducing airflow through the motor and causing the over heating.
If your motor runs at all, you probably have a blockage. Replace the filter inside the bag compartment just before the motor vent. Check the hose isn't blocked. Check the exit air filter.
If your turbine is clogged, it's a big disassembly job best done by a professional. If you really want to know how to cure it and feel you can tackle it yourself, email me. alan_at_alanjohnston_dot_com.
If your motor doesn't run at all and the light just quietly comes on, you have a break somewhere in the thermal protection circuit, either in the wiring (unlikely) or inside the circuitry buried inside the motor itself. I had an open on the thermal switch where the combination of heat and vibration deoldered the thermal switch from its board.
Hope this helps.
Alan
May 21, 2010 | Vacuums
Miele, model # S 514 does not turn on.
Sounds like the cable may be damaged. I think you're going to need professional repair... sorry can't be more help.
Feb 17, 2009 | Miele S514 Solaris Electro Plus Vacuum
Miele vacuum cord reel question
I had to take off the cord reel and clean the contacts inside it. I also bent the contacts out since they tend to wear down after time.
Jan 23, 2009 | Miele S514 Solaris Turbo Plus Vacuum
Miele solaris turbo plus S514 will not start in live outlet
Jan 19, 2009 | Miele Vacuums
May 17, 2008 | Miele S514 Solaris Electro Plus Vacuum
Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
Miele S514 Solaris Turbo Plus Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
