I owen a 2005 itasca suncrusier. ineed to service the colman central air with freon and have no info manual on this, it is an under coach and not a roof unit
  • ken_riedinge Aug 01, 2010
    thanks i will try the manualguide to see if i can get th answear
    Genius:
  • 1,478 Answers
Although it is very dangerous to do this. I will tell you how to go about it.
You should have a set of gauges, called a manifold, there should be a red one and a blue gauge..
The red one is for the high side, the smallest of the freon lines and the blue one is for the low side, the larger of the tow lines going into your unit.
It is possible to connect the freon lines while the unit is running. Connect the red hose to the small freon line and if the ac is running this line should be hot or warm. Then connect the blue hose to the large freon line and it should have some sort of insulation on it and if you feel it, it will be cool if you have enough freon in the unit.
You read the gauges like this. With the ac unit running first look the high side(red gauge and hose) you should have a thermometer set where the outside air is being pulled through the unit by the condenser fan, the fan on top or somewhere in the unit that blows air across the coil. (radiator looking thing)
If the ouside air temperature is 100 degrees you add 32 to that which gives you 132. On the red gauge you will see small numbers below the outer numbers and these numbers are green for freon 22 and other colors for other freons and assuming that you have freon 22 in your ac unit these are the numbers you have to look at.
The outer gauge at an outdoor temp of 100 degrees should read around 296 0r 298 psig (pounds peer square inch)
The low side, the blue gauge, depending on the inside temp of your house should be around 60-65 psig if inside of the house isn't too much over 80 degrees. Any higher temp inside your house it will be higher than the 60-65 degrees.
If the readings don't match and you feel it needs freon NEVER charge the system through the high side (small tube) use the low side and don't turn the freon gas can upside down because you will be sending liquid freon into the compressor and that is called "Slugging" it. A no-no.
The blue gauge will also give you some information. Look at the outer gauge and if its near 65 degrees in your house, look at the smalll green numbers and you will see that the coil temperature is.
Hope this works for you. It is a very involved thing and you really should have an someone with some ac experience near by.
Take care.
Posted on Jul 31, 2010
    thank you for the info, but i have a problem with locating the area in which to service the unit. the central air colman model# 6535-671, is there a chance to get a copy of the manual on this unit?
  • Jimoh Adeleke Muyideen Aug 01, 2010
    Check manualnguide.com to search for the manual of your air conditioner.
Coleman mach rv central air conditioner maintenance
maintaining rv a/c is just a matter of changing filters, cleaning coils and drain lines. visual inspection of wireing for heat damage.
Jun 18, 2014 | Coleman Heating & Cooling
Slide wont come in
The slide system usually uses inline circuit breakers to control the power for the slide. Some are automatic reset and others have a small black button on the side that must be reset. On a motor coach you will find these in a storage compartment and they probably will not be labeled.
Feb 06, 2014 | Itasca Navion 24A RVs
Central air freezing up
Low freon causes this problem. It could be the compressor going bad, but 99% of the time it is that the freon is low, have it leak tested and also have freon added
May 23, 2009 | Heating & Cooling
Ac is blowing warm air in my 2005 sierra 2500hd duramax. Any idea
Your system has R-134 Freon in it. the 134 is made up of smaller molecules than the old R-12. The R -134 permeates through the rubber parts of the system. If the system gets too low on Freon, the compressor will stop coming on.(low pressure cut out switch). Have the system serviced with an A.C. machine that can vacuum, measure the amount of Freon in the system, and add the right amount. The machine can also inject die. Later the die will show up under a black light.This will show any leaks you may have.
May 23, 2009 | 2005 GMC Sierra 2500HD 4WD
Haier central ac unit problem
HEY,Kim, connect the red hose with the crooked end on the small line service vale and the blue crooked end to the fat line service valve and read the preassure now. Also the yellow line connect to the refrigerant tank...!
Jul 09, 2008 | Haier Energy Star ESA3183 Air Conditioner
Air conditioner
open the hood it will tell you what kind of freon it needs also your owens manual.and remember turn car on and and ac on high conect the freon hose that it comes with shake the can and turn it upside down when filling the ac if your a lady please put your hair in a bunn and make sure you dont have any loose things on hope this helps aways be safe around cars
Jun 26, 2008 | 1992 Plymouth Acclaim
Fair price to fix central air conditioner leak & refill with freon
I have heard that there is a spray you can use that will not damage your system and seals the leak when it comes in contact with oxygen
Apr 18, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
