Question about Bushnell Golf Medalist BUU0055 Rangefinder
Rangefinder has e33 in display - Bushnell Golf Medalist BUU0055 Rangefinder
Which is the best golf laser range finder?
Bushnell Scout DX Rangefinder is a good one for golf.
It's a fantastic rangefinder.
It offers some amazing feature and specification like...
  • 6x magnification.
  • Range between 5-1000 yards.
  • 3-volt CR2 Battery.
  • Rangefinder Accuracy 5 yards.
The Bushnell Scout DX Rangefinder will help you to pick from 3 different user modes by pressing the Mode button at the left side of the unit. First is the usual mode which can be used for most purposes up to 1000 meters and works well towards the pretty reflective surface.
When turned on, the Scout 1000 Laser Rangefinder liquid crystal display (LCD) will directly display icons like the bow and rifle mode. The bow mode will provide you with true horizontal distances from 5-99yd away, depending on the angle. The rifle mode, however, will permit you to get the angle and drop/holdover of your shot to the target from 100-800yd.
Mar 03, 2018 | The Optics
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
How to reset E33 machine
Replace the toner, open and close the front door several times and let it cycle until the E33 disappears. Comes from copying even after add toner display comes on.
Aug 18, 2014 | Kyocera Mita KM1500 Fuser Fixing Unit -...
My rangefinder displays the middle square but nothing else. it has a new battery
My Leica Range finder displays the square but nothing else. It has a new battery. some time it shows - - -
Nov 18, 2010 | Leica LRF 1200 Laser Rangefinder
My rangefinder is not able to pick distance more than 175 yard
It needs an alignment.....Dropping and vibration are killers to Pinseekers. For all you players that take the eyepiece cap off.....very bad idea. This is why you see little oily looking or black spots in your display. Sunlight permanently damages the display.
It can be repaired. >time and money needed<
good luck
mr tech geek
Jun 26, 2009 | Bushnell PinSeeker 1500 20-5103...
Display will not clear
If all the LCD display segments will not clear or E31 is displayed.....It needs programming and/or a new CPU board. Usually, leaving batteries to die (in the off season) or using heavy duty batteries can cause this.
MTG
Jun 21, 2009 | Bushnell PinSeeker 1500 20-5103...
No yardage displayed
The rangefinder is out of alignment. Vibration, dropping these units make small mirrors inside move slightly. Over time the receiver cannot see what the transmitter puts out. Bushnell can fix, 4-5 weeks w/o unit.
Mar 18, 2009 | Bushnell PinSeeker 1500 20-5103...
Bushnell medalist pinseeker rangerfinder
You must use alkaline batteries only.....Heavy duty batteries dont generate enough current to power the laser properly...
mtg
Aug 23, 2008 | Bushnell Medalist Rangefinder
Error code er6
Take the nice cover and neck strap off rangefinder to use on another item. Next use the rangefinder for hammer. boat anchor, etc. Seriously though the problem occurs often in the Bushnell rangefinders and it cost more to fix than to replace with a better brand. A $179.00 original cost rangefinder cost $10.00 to ship back to Bushnell and another $235.00 for repair of a non specified problem for a grand total of $245.00. I consider this a rip off from Bushnell.
Dec 09, 2007 | Bushnell Yardage Pro 600 Rangefinder
Display
Here is the link to the instruction manual if you need it; http://www.bushnell.com/customer_service/manuals/rangefinders/20-0002_YP_Tour.pdf half way down page 2 on the left are their troubleshooting suggestions - if none of those i would suspect the battery, if a new battery doesn't solve it then contact bushnell; http://www.bushnell.com/dealer_locator/locator.cfm?section=General%20Use Hope this helps :)
Mar 17, 2007 | Bushnell Yardage Pro Tour Rangefinder
Bushnell Golf Medalist BUU0055 Rangefinder Logo
259 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
