Question about Creda W120VW Front Load Washer
Creda W120VW washing machine - Energy & Deep Rinse Buttons. How do they work?
I have recently moved into my new house the purchase of which included a Creda W120VW washing machine. It is working perfectly fine. However, in the absence of the instructions manual, I am unable to work out whether the 2 optional buttons for energy saving and deep rinse must be pressed in or not, in order to turn those settings on. You see, the turn on/off button turns the washing machine on when it is NOT pushed in, i.e. that the little green mark at the bottom of the button is showing. Does this therefore mean that the 2 optional buttons work in the same way? Please let me know. I look forward to hearing from you very soon. Many thanks. Reena
I found the manual on a website which I didn't note down, but which was very useful as it had almost every washing machine manual on the planet! Now I know that the energay saving and deep rinsing buttons are activated by pressing them in. Thanks anyhow for your attempt to help!
Posted on May 21, 2008
  • john tyler Nov 08, 2012
    I was just given the W100FW today, i downloaded the manual just to find the answer to this very question, but i couldn't find it in the manual either!! Thanks Reena77 for leaving an answer to your own question! :) You help me too
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Creda excel 2000 skips spin and rinse cycle
The filter is located in the sump hose at the rear of the washer.
Remove back panel and undo the clip that holds the large black hose onto the rear of the drum .
Inside it ,you will find the filter.
Remove and clean.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Creda W120VW Front Load Washer
Rewiring Creda W120vw door
THEY ARE BOTH LIVE WIRES THE RED/GREEN ONE GOES NEAREST TO THE DOOR SEAL, AND AS I SAID THEY ARE BOTH LIVE SO PUTTING EITHER WAY WOULD NOT CAUSE A PROBLEM APART FROM ONE WAY THE MACHINE WOULD NOT WORK. I ASSUME THE BLACK WIRE IS ON THE MIDDLE CONNECTION, THIS IS NEUTRAL
Jul 15, 2008 | Creda W120VW Front Load Washer
Creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Apr 17, 2008 | Creda W120VW Front Load Washer
Problems with creda washing machine
try your carbon brushes and drop your sump ie the pipe that connects to the pump on the inside of the machine and goes to the bottom of the drum this is the sump that sometimes blocks or may be a weak pump but try the other 2 options first good luck dont forget to unplug
Apr 14, 2008 | Creda W120VW Front Load Washer
Re: Creda W120VW
is the machine on its own circut
Mar 29, 2008 | Creda W120VW Front Load Washer
Creda W12oVW
hi m8 if the drum is solid then it could be the drum bearings which is a big job also check between the inner and outer drum to make sure there isnt nothing there
Nov 10, 2007 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
121 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
