Question about SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader
Sandisk 8GB SD micro memory card unreadable
I have a Sandisk 8GB SD micro memory card, which I was using with a Panasonic Lumix camera. Recently when I turned the camera on it read ''Memory card error, please check the card'' and would not allow new pictures to be taken or old pictures to be viewed.
When I plugged it into my computer it took a long time to load the autoplay, which simply kept on searching and never actually ran the card. While the removable disk does eventually show up in ''My Computer'', double clicking or right clicking on the drive icon both freeze the window. The program ''SD formatter'' apparently does not support the drive either, and between these issues I cannot reformat the card.
Having tried a different adapters and cards with two different laptops and the camera (in all combinations), the problem does rest with the micro memory card itself. Any ideas?
  • 94 Answers
SOURCE: SanDisk Micro SD Card problems.
the card needs to be formated on n73.
if still not work than the card is faulty
Posted on Jun 12, 2008
  • 3 Answers
SOURCE: Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
Posted on Dec 29, 2008
  • 142 Answers
SOURCE: MY 2GB MICRO SD MEMORY CARD USED 2 WORK NOW READ ERROR
will the card work in a computer?
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Posted on Jun 12, 2009
1alexh
  • 484 Answers
SOURCE: Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Posted on Jun 14, 2009
I have a panasonic lumix DMC-FZ20 camera that i installed an 8g memory card but it says memory card error
The DMC-FZ20 works with MMC and SD cards, 2GB or smaller. Your 8GB card is an SDHC card, which fits into the slot but is electronically incompatible.
Feb 22, 2013 | Panasonic Lumix DMC-FZ20 Digital Camera
How do i repair sandisk micro sd card
Hi....
If you lost your data from sandisk memory card then you can use one of the sandisk memory card recovery software that is available online in order to recover files from sandisk memory card.
Dec 06, 2012 | Samsung 8gb Micro Sd Memory Card 4 Galaxy...
Sandisk micro memory chip not working in my lg620g cell phone
The LG620g works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work in this phone. You need to use microSD cards, 2GB and smaller.
Nov 30, 2012 | SanDisk 8gb Micro Sd Memory Card Class4...
Panasonic Lumix ZS7. Getting error "Pictures will
The mode dial on the top of the camera is set to clipboard. Turn the dial to P or iA.
Jan 10, 2011 | Panasonic Cameras
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Bought a new Sandisk 8GB microSDHC card (Product Description : Micro SD/8GB SDSDQ-8192-P36M) for my Nokia E51. It worked fine for two months, in this had many times used in PC with my card reader for...
try formatting ur card with the following steps:
right click om my comp then click on manage then disk menagement and right click on ur card then format it will forcely format ur card. gud luck....
Oct 19, 2009 | SanDisk 8GB microSDHC Memory Card with...
Is lumix dmc-fx33 compatible with sandisk ultraII 8gb sdhc cards?
No, 8 GB is too large. According to page 5 of the manual, 4 GB is maximum:
•When the term card is used in these
operating instructions this refers to the
following types of Memory Cards.
– SD Memory Card (8 MB to 2 GB)
– SDHC Memory Card (4 GB)
–MultiMediaCard (still pictures only)
More specific information about memory
cards that can be used with this unit.
• You can only use an SDHC Memory Card
if using cards with 4 GB or more capacity.
• A 4 GB Memory Card without an SDHC
logo is not based on the SD Standard and
will not work in this product.
The manual can be had below:
http://service.us.panasonic.com/OPERMANPDF/DMCFX33.pdf
Oct 05, 2009 | Cameras
Sandisk 4gb micro SD with adapter is "unreadable"
Certain cameras will not recognize an SD card because it is SDHC. The format was created after the camera. Camera vendors do issue firmeware updates.
Hope it helps.
Aug 27, 2009 | SanDisk 4GB Secure Digital High Capacity...
MicroSD SanDisk 2GB memory into Panasonic DMC-FZ7
Hey filmoman2008,
If you are really trying to use a micro SD card this camera actually takes normal SD memory cards not micro SD cards.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 25, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
349 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
