I do believe most manufacturers recommend emptying the strainer after each wash (much like you would a lint filter on a clothes dryer). With the door open, look inside on the bottom. You should see a plastic cylinder shape about 2-3" in diameter. Twist it counterclockwise and gently pull up. This traps large pieces of food, and the occasional piece of plastic wrap, toothpicks, etc. that seem to get past the kiddos when they load it. If you find large amounts of food particles, I suggest pre-rinsing pots, pans, plates before placing them in. Good luck, and please keep us informed of the progress on this concern.
SOURCE: broken nozzle and upper spray arm
the spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
SOURCE: cleaning out debri in pump
if youve acess below the filter screen ther is only 2 more screws holding down 2 more covers giving you acess to the chopper assy, this is where youll find broken glass and stuff hitting against hte chopper try to break up.. the first of 2 covers lifts right off,,, the second will require sorta prying up and off, beyond this no real acess to any more
SOURCE: Top spray not functioning in dishwasher
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming
the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to
access the wash motor. Remove the 4 torx screws and the filter
(accumulator assembly). Remove the torx screw and the inlet protector
that covers the chopper assembly. Make sure the chopper is not broken
(broken chopper will fill with debris and block water flow). While
holding the chopper blade, reach inside the "D" shaped opening on top
of the motor and spin the wheel/motor by hand in each direction to make
sure either the chopper gear or the motor gear that drives the chopper
is not broken. Replace the chopper if necessary (part # 8268383). If
the motor gear is broken, replace the sump and motor assembly (part #
8535150). Remove any debris from the sump area in the process.
You
don't have to shut the power off to the dishwasher because the door will be open, but if you feel more
comfortable, do so.
SOURCE: Maytag dishwasher filter keeps clogging
There is a product made to filter the water going into your dishwasher only to soften the water and remove the calcium before it enters your dishwasher. your dishes will be spotless and it will not get clogged again. you can get it at www.dishwasherfilter.com. it goes right under the sink and is very affordable. you will love this product and it will solve your problems.
SOURCE: my top rack is not getting clean,
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
