Question about HEALTHRIDER R60 SoftStrider Treadmill
Console lit but none of the pushbuttons function except for incline and there is no motion. The speed switch has been alligned to 1/8" gap. Plesae help with advise. Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
Posted on Aug 13, 2010
Buttons on console do not work, except no. 2 speed button and +/- speed buttons
Here is a solution for those of you who have experienced recurring dead buttons on the console. For me, all buttons would function initially but after a few minutes of use (belt running), all buttons would stop functioning except speed buttons 5, 7 and 12. Switch off, unplug the treadmill and all button functions would come back on next power-up hours later.
The problem is that the electronics cannot handle the static electricity generated by the running belt motion. The static in your finger as you press the button penetrates the thin membrane switch and goes right into the electronics. It takes several hours turned off for the excess charge to dissipate and control to be restored.
1. Gently peel the button decal off for both sides (incline and speed), do not remove or pull on the flex circuit underneath. This is the membrane switch.
2. Use the decals (sticky side up) to trace the outline on paper and tin foil and carefully cut out the profiles.
3. Stick the paper in using looped or double sided tape, careful not to place tape over or near a button locations. I used white printer paper because it is not very thick. A layer too thick pay prevent the button from working.
4. Place tin foil cutout over the paper. The foil needs to be connected to earth ground (the 3rd pin on the power plug) and I don't trust the frame is properly grounded so I ran a wire from the foil in the console to a grounded screw near the power switch (where the plug wire ground connects). Make sure the treadmill is unplugged when you are working on it! The incline and speed side foil sheets are also connected with a wire.
5. Cover the foil layers with a layer of clear packing tape to protect the foil if you ever need to remove the button decals again.
6. Check function and if all is well, replace the button decals.
The paper increases the dielectric strength while the foil layer shunts the static charge of your fingers to ground. Since I made this improvement it has run perfectly! Good Luck
Jul 31, 2014 | Epic 400 Mx Treadmill
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Jazfit T38R Incline up button beeps but doesn't do anything.
Dear Sir:
1(any signal from the console which could be a damaged cable 2(or the console itself has failed. 3(motor control board may have failed from a worn treadmill belt and deck 4( the motor may have burnt out. 5(potentiometer geared to the motor so the console knows what height the incline is at.6( gearing can slip, giving the console.
RUN THE software calibration for Help and trouble
see my personal TIPS for HELP
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Mar 10, 2012 | Exercise & Fitness
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
I need to know where the batteries go
Dear Sir: I will help you, please do the following step: Instructions Things You'll Need
  • Power supply
  • Standard screwdriver
  • Batteries
  • Access to local fuse or circuit breakers, if necessary
    • 1 Check to see if the Pro-Form device is properly plugged into a working, grounded power supply if none of the console buttons are working. Turn the device on and reset local fuses or circuit breakers if necessary; reset the circuit breaker switch on the base of the unit.
    • 2 Turn off the fitness device and unplug from the power supply if the console only shows zeros or the console buttons are not working. Use a standard screwdriver to open the battery compartment on the underside of the console. Pull out the old batteries and recycle, if possible. Replace with new batteries, using the old batteries as a guide for the size and type of batteries needed. Place the flat end of each battery against the spring inside the battery compartment and gently push the battery into place. Close the battery compartment and restore power.
    • 3 Press and hold the "Stop" button if the console is only flashing repeatedly, indicating that the device is in demo mode. Insert the console key and push the "Speed Down" button to turn off the demo mode on the unit. Remove the console key.
    • 4 Reset the console buttons if the incline is not working properly on the machine. Insert the console key and press one of the "Incline" buttons. While the incline is in the process of changing, remove the console key. Wait two or three seconds and re-insert the console key.
    • 5 Remove the console key and unplug the Pro-Form device if none of the above steps are resolving the problem with the console keys. Unscrew the three screws that hold the motor hood on the front of the device and pivot the hood off the machine. Find the magnet and small reed switch on the left side of the pulley. Turn the pulley until the magnet is aligned with the reed switch and the gap between the two is approximately 1/8 inch. Reattach the hood, screw into place and turn the treadmill back on
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 16, 2011 | Proform XP Weight Loss 620 Treadmill
Only one program works. you can start manual but have no control over speed or incline.this is a proform frontrunner
Dear Sir:
I will help you inmediately.
SOLUTION: a. Remove the key from the console and unplug the
power cord. Remove the screws from the hood and
carefully remove the hood. Locate the Reed Switch
and the Magnet on the left side of the Pulley
. Turn the Pulley until the Magnet is aligned with
the Reed Switch. Make sure that the gap between
the Magnet and the Reed Switch is about 1/8ó. If
necessary, loosen the Reed Switch Screw and
move the Reed Switch slightly. Retighten the Screw.
Re-attach the hood, and run the treadmill for a few
minutes to check for a correct speed reading.
Please check it and contact me if there are any additional help. blessing. sincerely.
E.Cuadra
Managua, Nicaragua
Sep 13, 2011 | Proform Exercise & Fitness
I have a Nordictrack Solaris C2050 with the controls not always working. Sometimes the panel and contrals with perfect other times only a few buttons work, like the 7MPH, reduce speed. This problem is...
I have the same issue I don't think anybody (including the supposed "experts") really know what they are talking about. The buttons work until they don't and then a bunch of them all stop functioning at once. The advice I always get is "replace the console" which amounts to saying "I don't know what's wrong" If I had to guess I think a static discharge has damaged the contoller board which doesn't manifest itself until the machine (and hence the board) warms up. Anyhow I haven't found a real solution to this issue if anyone has any real knowledge please post your solution.
Apr 09, 2010 | Nordic Track NordicTrack Treadmill, A2550
Elevation has gone too high. foot rollers are hitting front plate
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
HEALTHRIDER R60 SoftStrider Treadmill Logo
308 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
greg kinsley
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
