Question about Amana NDE7800AY Electric Dryer
The dryer works but there is no hot air. How can I tell if it is the heating unit or the heating sensor that is bad? Amana NDE7800AY
    President:
  • 3,773 Answers
Ohm the heating element for continuity
There is a thermal cutoff at the top of the element case with 2 wires
Hook these two wires together for a check or ohm it for continuity. . The dryer should run. unless it is a more tech problem.Also check for 230 volt at the wall and at the service cord at the dryer. A dryer will run on 115 but it will not heat.
for more questions.
Leo Ponder
imufo2@sbcglobal.net
Posted on Aug 01, 2010
What can be wrong when the dryer is running but there is no heat?
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 10, 2011 | Amana NDE7800AY Electric Dryer
I have a speed queen dryer and all it does is hums and instantly has a burning/hot smell. Any help would be great, thanks.
Hello James,
If you can rotate the dryer drum easily by opening the door and rotating by one of the drum baffles and it rotates easy and noise free,the problem is going to do a bad motor
Gene
Aug 08, 2011 | Amana NDE7800AY Electric Dryer
My Amana Drier Model LE8407W2 stopped heating (everything else works fine). After checking the vent, I have decided to examine the heating element but am having difficulty accessing it. I have removed...
Most dryers are designed to be repaired from the rear. On the rear probably the whole back panel unscrews. Giving access to the duct where the heating element is located. Make sure to have the dryer unplugged while servicing it to prevent getting electrocuted. Your heating element will be inside of a metal duct that feeds hot air into the dryer remove it and inspect it for breaks in the coils of wire or burned areas. Having a good volt meter that checks continuity is a great tool to check dryer parts. There are several over heat sensors that can go bad over time to and can prevent the dryer from heating. These sensors and the heating element can all be checked using the volt meter on the continuity setting. Having a cell phone on hand helps to take pictures of wiring and connections inside the dryer before unhooking them to aid in reassembly. With sensors or element unplugged and a volt meter on continuity setting touch the red probe to one side of a connector and the black probe to the other side if there's no numbers or a beep on your volt meter suspect that part bad. I have fixed several dryers this way. Hope this helps you.
Jan 17, 2018 | Amana NDE7800AY Electric Dryer
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
The problem I am having with my Amana model NED7800AYW makes a loud noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgs453q2
May 15, 2010 | Amana NDE7800AY Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Dryer quits after being used for a while and won't turn back on
It is overheating.
You are luck it puts out any heat.
You didn't say if it was Electric or Gas?
If electric, the the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on or shut off prematurely (Gets too hot too quick).
If Gas, the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldn't heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-) and my Furnace turned on and off for 10 minutes b/c the airflow sensor was jammed.
If you do the troubleshooting, do NOT forget to unplug first!
Mar 27, 2009 | Dryers
Gas dryer continues to run on the Auto cycle.
try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
Mar 27, 2009 | Amana DLG330RAW Gas Dryer
My dryer stopped heating. Everything else seems to work. It still runs, but only feel cold air.
Electric or Gas?
If electric, the element is gone or a fuse blew or the airflow thru the dryer is restricted or a sensor is bad and 'lying' to the CPU. Check the filter, check the hoses for lint, check the outside vent flap to be sure it isn't stuck (possibly painted) closed. The air has to BLOW a certain CFM or neither ELEC or GAS type will turn on.
If Gas, the pilot isn't lit or the electronic ignition isn't firing or the gas supply valve is bad/stuck or the thermocouple that tells the CPU that the 'heat is on is 'lying' or the sensor that tells the CPU the Air movement is OK' is bad.
My dryer wouldnt heat because a thermocouple in the exhaust pipe was lying - stuck ON and telling the dryer it was already hot enough. ;-)
Mar 26, 2009 | Dryers
Amana NDE7800AY Electric Dryer Logo
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
