Question about Toshiba Satellite A215-S7422 Notebook
Computer just died.. no lights whatsoever. power
Computer just died.. no lights whatsoever. power out let is good. doea that sound like the battery just died/
  • Toshiba Master
  • 11,800 Answers
Take out the battery and try to start from the charger - if it's the same then you had a major hardware failure , most likely your motherboard has died. You need to take it to a repair shop for a precise diagnose and repair.
Posted on Jul 31, 2010
    Guru:
  • 1,082 Answers
Sounds worst than that. As a test, remove the battery and plug it back in. Does the brick have any lights? When plugged in hit the power button. If you get NO lights, it is time to think about a new laptop.
Laptop repair is not cheap.
Tried to install a headlight modulator in a 2011 Triumph Sprint GT. now I have no power whatsoever, battery drained replaced with a new battery and still no horn, lights, or power
It sounds like another fuse is blown or possibly a relay. Check all of them, if none are bad, then make sure your battery cables are good, use a test light to check them. Its more then likely a bad relay though. Good luck !
Apr 13, 2014 | Motorcycles
No electric
Main power wires going to battery need to be checked. Sounds like the battery may be bad or the connection from the battery is bad. Replace battery if it is at fault. If not, clean the terminals and make sure the wires are getting good contact next.
Sep 21, 2012 | 2004 Pontiac Grand Am
No power or lights to toshiba nb205-n210 netbook
Maybe your motherboard is fried. If you know for a fact that the power cord is good and that the DC Jack on the motherboard is good but nothing is happening then the board is just gone.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 05, 2012 | Toshiba Computers & Internet
Cq60-615dx power problem
Mar 31, 2012 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
1993 Chrysler New Yorker 5th Avenue - I need to clear the computer error codes and I read on here one day where a guy suggested I disconnect the negative cable from my battery and turn on the headlights...
Never heard that. Sounds like he's pulling your chain-when you disconnect the battery(that's how I clear my codes) you can't turn the lights on-no power! And even after you hook the battery back up, turning the lights on or off has no effect whatsoever on the engine computer.Just remember, you'll have to re-set your clock and radio pre-sets after re-connecting the battery.
Oct 11, 2011 | 1993 Chrysler New Yorker
I own a 91 Mercury ( ford) Capri convertible. I went to start it and it turned for a second then died. All power to the car died instantly. There is no lights no radio no lighter no instrument light no...
Has to be a cable connection issue of some sort. Check the other end of the battery cables, either the ground connection to the chassis, or power connection to the under hood fuse box. Could be that one of the battery cables has broken inside the insulation yet the connector looks good. Try using a cheap ohm-meter to see if there is a break in either cable ...keep looking!
Dec 15, 2010 | 1993 Mercury Capri
My Asus netbook won't power up at all. The last time it powered up I was able to login then I heard a whirring sound and the screen went black. Now there are no lights whatsoever on the netbook.
The whirring sound came from the hard disk - either it has died or thepower sent to it was too little to make it work .
Remove the battery and try to boot in the BIOS with the netbook attached to the charger - if you can't do that then you have a hardware failure. Remove the hard disk and try again - if it fails even now then the motherboard is gone.
Aug 24, 2010 | ASUS Eee PC 1000 Notebook
1990 chevy blazer no electrical power good battery/connection
sounds like a primary ingnition wire check your battery positive to your alternator and your pos to your starter
Jan 20, 2009 | 1990 Chevrolet S-10 Blazer
Compaq Presario V6000 Power Problem
Sounds like the power supply might have died, probably before the battery did. Once the battery had run down, the computer simply died. Easiest way to check this would be to take it to a computer shop - they shouldn't charge you very much just to check the power supply - or try to locate another supply just like it and see if the computer will boot from the new power supply.
Graye
Nov 09, 2008 | Compaq Presario 700 470024-192 Notebook
01 pt cruiser
I would go to autozone or something and have them read the computer in your vehicle.This will tell you what those codes mean.Than go from there.
If I had to guess,there is a short or the computer is bad.
Good Luck
Jul 11, 2008 | 2002 Chrysler PT Cruiser
Toshiba Satellite A215-S7422 Notebook Logo
238 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
