Question about Campbell Hausfeld CHN50399 2in1 Flooring NailerStapler Kit
I am using this product for a hardwood floor. I cannot seem to get the staples driven in far enough. I'm using 2" 15 gauge staples and have oiled and set the regulator correctly
    President:
  • 2,702 Answers
The wood may be to hard for the gun to drive the stapel right in or you may just have a worn out gun,,turn the regulater up some more to increase the guns power a little more it should hit the stapels a bit harder then,,,some wood is harder than others,,dont just go by what the book sayes! if it works,,,use your setting not what the book sayes, only back it off a bit if it berrys the stapel a foot beep in the wood!!!
Posted on Jul 31, 2010
How do you remove dried gloss paint from laminate floor
Try using a steam iron, put a damp cloth on top of the paint and then the iron on top and steam the paint, it may soften it enough to get it off with a plastic scraper so you don't mar the floor finish.
Sep 10, 2014 | Stanley Laminate Hardwood Flooring Staple...
Pneumatic Hardwood floor stapler from Bostitch is misfiring
Put a little gun oil on the staples the spring that helps feed them might be catching
Dec 19, 2013 | Stanley Hand Tools
Bostitch hardwood flooring stapler. The Staples misfire. I have to keep pushing on the Staples to make the gun fire properly
take a small brush like one you would use to clean a gun. clean it well and use gun oil to lube it
Dec 19, 2013 | Hand Tools
Not sinking the flooring nail down far enough
The pressure from your compressor needs to be 100psi at least. If you have a small compressor it may not be maintaining that pressure between cutting-out and cutting-in. Also you need to give the plunger on the top of the gun a fairly solid hit with the mallot. If you are fixing into old hardwood you could try a little bit of lubrication on the tips of your staples, candle wax may even help and is not to messy.
Good luck
Jan 13, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
The staples are not going deep enough into our hardwood. We tried a different nailer as well, and the cleats wouldn't work either. Tried both 1 1/2" and 2" staples and cleats. We're installing 3/4 inch oak...
The working pressure of this tool is 85 - 90 PSI max. Do not over power it or you risk O-ring breakage. These guns are adjustable for floor thickness. The adjustment is simply by adding and removing shims on the floor contact part of the tool. For 3/4" the pad should be 5/16" thick without shims
Jan 03, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
What size cleat/staple do I use for 3/4 hardwood flooring?
FLN-150 is 38mm staple and FLN-200 is a 50mm staple. you can buy them online in boxes of 1000. I would say choosing between the two depends on the thicknes of flooring you are using.
Jun 20, 2009 | Hand Tools
TRE 500 Staples don't go in deep enough.
Dial controls depth. Set it to "+." Watch out setting isn't accidently changed during use. Tre500 isn't powerful enough for hardwoods, etc.
Jun 04, 2009 | Electric Stanley Tre500 Staple Gun /...
Hardwood floor cleaner
Yes, you can use the Bruce hardwood floor cleaner. I've used it many times to clean up after jobs. It brings a nice shine to the floor and is designed for either a hardwood or laminate floor. Hope this helps.
Apr 19, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Campbell Hausfeld CHN50399 2in1 Flooring NailerStapler Kit Logo
122 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
