Question about Pioneer VSX-D412 Receiver
Display shows overload and receiver shuts down
After the reciever is turned on in a few seconds the display shows "overload" and receiver shuts down.
  • Pioneer Master
  • 11,800 Answers
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Posted on Jul 31, 2010
Testimonial: "Thanks for the advice, it was very helpful."
Receiver
If the display shows overload, you are playing it too loud, or have too many speakers connected. Overload is a protection method used to shut down the unit, before it's damaged.
May 31, 2014 | Audio Players & Recorders
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
As i increas the volume the reciever says overload and shuts down the amplifier, i can then either lower the volume all the way down wait several seconds before the audio comes back or just shut down the...
It sounds like either your speakers are too large for the receiver to power, or the way that the speakers are hooked up is incorrect. I would need some more information to be able to better determine where the issue is.
Jan 06, 2011 | Audio Players & Recorders
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
Power to reciever shuts down after 30 seconds of playing a CD
if it doesn't shut down playing the other inputs check the rails the laser rides on there may be dirt/hard grease stopping the sled. or the may be a power overload caused by a faulty cd player and you system is going into the protect...
Dec 10, 2009 | Audio Players & Recorders
Shuts down after 30 seconds
Maybe the audio amplifier IC are burned
Jun 29, 2009 | Pioneer VSX-D307 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Pioneer VSX-D412 Receiver Logo
557 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
