Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam Printer says there is a paper jam, but there isn't. How can I fix this problemM
  • 7 more comments
  • StevieT Apr 24, 2008
    The printer keeps flashing error code 3 which is paper jam. I've done all the troubleshooting suggested by the manual and it still flashes. There is no paper jammed in the printer!!! It's only 2 months old and rarely used so need help.
  • Anonymous Apr 27, 2008
    I try to print but it says the paper is jam, but it's not how do I fix it.
  • ELFudge May 14, 2008
    Paper Jam
    The printer keeps flashing error code 3 which is paper jam. I've done all the troubleshooting suggested by the manual and it still flashes. There is no paper jammed in the printer!!! It's only 2 months old and rarely used so need help.I cannot find help on the Canon web site
  • Anonymous May 14, 2008
    error code 3, says there is a paper jam and there isn't
  • Anonymous May 20, 2008
    The printer keeps flashing error code 3 which is apparently a paper jam. There is no paper jammed in the printer, have followed the trouble shooting guide, but still the same.
  • juanluk Jul 07, 2008
    I have the same problem and have completed everything as said in the troubleshooting. When it tried to bring the paper in to clean the rollers the paper will not feed past about 1 inch.
  • Anonymous Aug 18, 2008
    i have the same problem.i tryed unplugging it and looking in it for any papers. ive restarted it but nothing works.
  • ilovejosh Aug 18, 2008
    ive tryed unplugging it and restarting it and did a million other things but nothing worked.
  • eastonnunez Nov 06, 2008
    im not to good with printers but i cant even get the paper to feed into the rollers
I did exactly as iamzwalrus said and it fixed.go with that if nothing eles works.
Posted on Aug 18, 2008
A piece of paper may not be jamming the rollers, but something small, such as a sticker or, in my case, a tag I cut off of a shirt and set on top of my printer, may be stuck under the roller.
Take something stiff and push it under the roller from inside the printer. As soon as you can see it from the other side, remove it and restart the printer.
Posted on Nov 09, 2008
  • 3 Answers
Just power on the printer and force a single sheet of paper through the rollers.
Posted on May 24, 2008
The paper is feeding in a little sideways and so it jams everytime I try to print. I tried to clean the printer and run all the feeding cleaners, but nothing is helping...
Posted on Sep 19, 2008
2 Suggested Answers
  • 134 Answers
SOURCE: Printer indicates Paper Jam 2.
There is an issue with fuser exit sensor on this printer. They will report false paper jams. A small part needs to be replaced to solve the issue.
Posted on Jun 26, 2011
Paper will not feed
Hi, maybe there is still a little bit of jammed inside that you can\'t see. Try to see if there is and clean it. If you\'re sure there is no paper jam whatsoever, then there is a conflict with your feeding sensors or your cartridge isn\'t properly installed.
kind regards
Apr 17, 2013 | Lexmark X4650 InkJet Printer
How do I fix and avoid paper jam error issues in a Dell printer?
Fix and avoid paper jam error issues in a Dell printer-
Paper jam is one of the most common issues among all brands printers. Dell printers also show such issues and you will be indicated this error by the light or beep noise when a paper stuck inside. To avoid such issues on your Dell printer or fix the paper jam problem read here the useful tips that would be helpful to utilize Dell printing service with better efficiency.
Watch this video and fix paper jam issues in your dell printer:
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
My printer gives an error message "paper jam" when there isn't any jam
Paper is nearly always sensed with little, black levers that are pushed out of the way as the paper passes over it. Inkjet printers normally have just one sensor, while laser printers often have three to localize a jam in the paper path. Take out the paper and drum/toner assemblies and look carefully for the levers. See if they wiggle freely. Since they must be delicate enough to be pushed aside by a sheet of paper, it doesn't take much dust to stick one down, giving a false jam reading. A little wiggling and blowing might fix it.
Aug 18, 2011 | Brother Office Equipment & Supplies
Printer indicates Paper Jam 2. I followed all the steps. However, there isn't any paper jam. How do I clear this error? It will not clear.
Jun 26, 2011 | Samsung CLX-3170FN All-In-One Laser...
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Paper jam in pixmamp140
To fix a paper jam, you must first locate where in the printer the paper jam is, if your printer has multiple paper trays.
  • When you have located the jam, turn the printer off.
  • If you can see the paper, remove it slowly and carefully with both hands by pulling the edge out in the direction it would naturally be released.
  • Open the printer door to look for any stuck paper.
  • If there are bits of paper still inside the printer, take a piece of heavy-weight paper or cover stock and push it through the printer in the same path. This will push out any bits of paper.
  • Turn the printer back on. Repeat the steps if the printer still alerts you to a paper jam.
Jan 10, 2010 | Office Equipment & Supplies
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
343 people viewed this question
old marine
old marine
