Adobe 8.0 printer stall 2/3 way through when printing a pdf
    President:
  • 567 Answers
Hi the first option is to uninstall and reinstall the drivers for the printer,i am not sure what printer do you have so i can't send you the links.I you have the CD with the drivers for the printer you can use it, if you don't, you can tell the what kind of printer you have and what operating system is on your computer and i will send you the link.
Posted on Jul 31, 2010
  • 4 more comments
  • dtosh Jul 31, 2010
    I WAS NOT CLEAR. I CAN NOT MAKE A PDF FROM ANY PROGRAM - WORD EXCEL AUTOCAD QUICKBOOKS ADOBE 8.0- IT IS THE ADOBE PDF PRINTER THAT IS THE PROBLEM.
    I MENTIONED I UNINSTALLED ADOBE 8.0 PROGRAM AND REINSTALLED IT
  • Hilton Bristol Jul 31, 2010
    Top Adobe Acrobat Troubleshooting Issue
  • Try the following if you are unable to click on "Accept" or "Deny" for the software license agreement and have one or more of the following symptoms: you don't see the "Accept" or "Deny" buttons; when you move the mouse over the buttons, it changes to an editing cursor; or, the "Accept" and "Deny" buttons disappear when you click somewhere else in the dialog box.
    First, press "Enter" to accept the license agreement. If this does not work, change your screen's resolution to 1024 by 768. Finally, try setting the display dots per inch and font size for your video driver to "Default" or "Normal."
  • Installation Problems
  • Before installing, make sure that your computer satisfies Acrobat's minimum system requirements. Install Adobe Acrobat from an account with administrator privileges. If Acrobat does not install successfully, create a new administrative account and try installing Acrobat from that account. If the software does not install, reboot your computer and then copy the "Acrobat" directory from your DVD to your hard drive. Run the installer from the "Acrobat" directory on the hard drive.
  • If the installation does not complete successfully, reboot your computer and delete the temporary installer files before trying to reinstall. Go to "Documents and Settings/(your user account name)/Local Settings/Temp/" and delete any files you find there. Next, defragment your hard drive and run a virus scan. Install Acrobat when the scan completes. If it doesn't install, reboot the computer and try to install Acrobat again, but this time select "custom" on the install menu. Select only the minimum required files. If they install correctly, reboot your computer and start the installer again. This time, select "Modify" and add one additional feature that you want installed. Reboot your computer and repeat this install process until you have installed all the features you want.
  • Cannot Print a Specific File
  • If you can't print a PDF file, try to print a different PDF. If you successfully print the second file, the first file could be damaged. First, try to print the file as an image--select "Advanced" from the print dialog, then "Print as image." If that doesn't work, use "Save as" to save the file under a new name, then try to print the new file. If it doesn't print to your printer, select the Adobe printer and print to that--it will re-create the file.
  • Try printing the re-created file on your printer. If you still aren't successful, try printing the file one page or one section of pages at a time to see if you can discover what part of the file has the problem. When you discover the problem, redo or remove that page.
  • Cannot Print Any PDF File
  • If you cannot print any PDF files, try to print another file type, such as a text file. If this works, restart your computer and try to print the PDF file again. If that doesn't work, turn off your printer and wait 30 seconds. Turn it back on and try to print the file. If you still aren't successful, try printing from another computer or to another printer.
    STILL NOT THESITUATION. EXCEPT FORPRINTING ADOBE 8.0 WORKS OK. I CAN NOT MAKEA PFD FROM ANYPROGRAM WHEN I SELECT ADOBE PDF PRINTER. IT STARTSTO PRINT, ASKS FOR A FILE NAME, STRTS THEPROCEES AND WHEN THE PROGRESS BAT IS 2/3 ACROSS IT FREEZES BOTH THEPRINTER AND ADOBE. THEN I HAVE TO CANCEL THE PROGRAM TO GET RID OFTHE PRINT.
    Hi i now understand the problem,the version of adobe which you are using seem to be not compatible with your computer,you should should uninstall it and install a different version of adobe reader.
    PRINTING WINGDINGS WHEN I PRINT PDF FILES
    Adobe PDF reader tends to print webdings/wingdings in its version 8 incarnation. Download FOXIT reader free from filehippo.com and try to print your document from that instead of Adobe. This nearly always fixes the problem. antosarmy
    Nov 25, 2009 | HP DeskJet 5550 InkJet Printer
    Up until 2 weeks ago I was able to print PDF files on any printer from my computer, after an upgrade to Adobe Reader and Adobe 9.0 professional, I can click away on file print or the print icon and nothing...
    You can try to restore your computer to a time/date when things worked correctly: Start-Programs-Accessories-System Tools-System Restore. This process is fairly quick.
    Nov 07, 2009 | HP Officejet Pro L7680 All-In-One Printer
    Can't print multiple PDF files in 11x17 format. I open windows explorer and select the specific PDF files. Click on File, Print. They all print out, but they all are 8 1/2 x 11 on a 11x17 paper, instead of...
    Adobe Reader can be real pain it the... neck sometimes.
    But first I would inspect not only the printer setup, but also printer's default print settings. Windows XP has 3 places, where you can see the printer options:
    1. Printer properties
    2. Print preferences
    3. Default print setup.
    The third one is the one you have to set. When you double click on your printer icon, a print queue window opens. Choose Printer->Properties, go to Advanced tab, and on the bottom there's a button "Default print setup" (I don't have English XP handy, so I'm translating back to English from my version - excuse me if they might appear a little different).
    It's there you need to set up the default page size and so on.
    If this still doesn't help, try opening Acrobat Reader, setting the Page Size Scaling to None, printing something and closing Acrobat Reader. From what I've seen, it tends to remember this setting from previous sessions.
    You may also try alternative PDF readers, like Foxit Reader or PDF Xchange Reader.
    Good luck :)
    Oct 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
    I can print PDFs if I print from Preview (mac) but when I try to
    You can try these steps and let me know the result.
    === Problem Printing from Adobe ===
    1. Open PDF document.
    2. Click on 'File' menu.
    3. Click on 'Print'. Print window will open up.
    4. Click on 'Advanced' button on the left bottom of the popup window.
    5. Put a check mark next to 'Print as image'.
    6. Click on 'OK'.
    7. Select the 'Current Page' from the 'Print Range' option.
    8. Click on 'OK' to print one page of the document and see.
    === Enable Background Services ===
    Background Services to reduce the memory for printing issues from applications like Adobe, Power Point,etc.,
    1. Click on 'Start'.
    2. Right click on 'My Computer'.
    3. Click on 'Properties'.
    4. Click on 'Advanced' tab.
    5. Click on 'Settings' under 'Performance' Settings.
    6. Click on 'Advanced' tab in 'Performance options' window.
    7. Select 'Background Services' for 'Processor Sceduling'.
    8. Click on 'Apply', then 'OK'.
    9. Click on 'ok' button on 'System Properties' windows.
    Sep 28, 2009 | HP LaserJet 3600n Printer
    Exactly the same problem - any PDF from any PC causes paper jam
    You might want to switch to an alternative to adobe if that is what you are using.
    I have been an adobe fan and user for years but changed about 8 months ago and have never looked back
    it is a program called FOXIT
    Not only does it do more than Adobe reader it is much much faster at opening and printing PDF files.
    It is the only TRUE alternantive to adobe
    Aug 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Can't print a pdf file
    Sounds like you are using the PDF printer as your selected printer - this is for creating PDF files in which case you would give it a name.
    If you have a PDF file open, simply select your printer (1610) as the printer to print to as with any other documents you print.
    Dec 29, 2008 | HP PSC 1610v All-in-One Printer
    Msg 'unable to start print job, is printer available'
    A customer called me with the same msg. Let me explain first what the problem was..they had a Graphic PDF that on the HD was 20 MB but when extracted was well over 200 MB..first I had thought the pdf was exeeding the Printers memory but after testing it was not. The customer was printing the document using adobe PRO I had him print the document in reader 8.1 and made sure the print as image under advanced was selected and the document printed..
    Aug 09, 2008 | HP PSC 1410v All-in-One Printer
    Office 2007 professional and Adobe 8 Professional problem
    Very simple fix. Now and then after an Adobe Acrobat update Office will disable Adobe Acrobat as it is an add on. All you need to do is re-enable Adobe Acrobat. In Office 2007 goto Word Options, Add-ons, and at the bottom of the page is Manage. Click on the down arrow and select Disabled Items and click on GO. Re-enable Acrobat and you should be fine. In Office 2003, goto Help and selects disabled macros and re-enabler Acrobat.
    Feb 25, 2008 | Microsoft Office Professional 2007 Full...
    This is the same software. What type of printing problems are you experiencing?
    Nov 06, 2007 | Computers & Internet
    Computers & Internet Logo
    Alun Cox
    David Payne
    David Payne
