Question about Linksys Wireless-G Broadband Router
Need to know how to hook to cable sys - Linksys Wireless-G Broadband Router
    President:
  • 2,571 Answers
Not quite sure what your problem is......BUT
If you want to know how to set up your network equipment.
You should have a cable coming into your house with your internet/tv services. This has a "F" type screw connector on the end.
This screws into the back of your Internet providers "MODEM".
You connect the MODEM to your ROUTER with an ETHERNET cable (this has RJ45 plugs on). It plugs into the WAN socket on the router.
When first setting up the router, connect the router to the pc with an ethernet cable, log into the router via your browser. change the settings as needed, and set the security to WGA2 if possible.
Create a security password, save your settings, unplug the ethernet cable from your pc/laptop and try and connect via WIFI.
Hope this helped a little
Posted on Jul 31, 2010
1996 buick park avenue,battery goes dead after a couple of days ...i used a test light between the neg on the battery and the neg cable...id does light up...no lights are staying on, and no cig lighters...
you need to hook up a dvom meter to the battery to check and see if your alternator is putting out 13.5 to 14.6 volts hook the meter to the alternator first get your reading then hook it up to the battery should have pretty much the same reading if not your battery cables have to much resistance corroded . or you can take the alternator off and have your local auto parts store test it for free same goes for your battery. Your battery could be bad even know you it says 12.6 volts they need to do a load test on it to see if it holds up under all your accessories then if your battery and alternator checks out fine and cables check out fine then I say you diffidently have a pacitic drain problem .
Oct 29, 2013 | 1996 Buick Century
How to hookup audio to home security sys
do you have audio cameras, they don't usually give you the audio cameras with a standard setup, on the back of the dvr there is a plug for audio its either a phono plug or a mic input socket, this can be used in one room or outside depending on the mic you have to buy. you then wire this up to the cctv and have to setup the sound to the camara number.
Jun 24, 2013 | Zmodo dvr-dk41103-1tb cctv 4 ch home...
HW-e550 connection
If you have a newer tv with an optical audio output, that would be the easiest way to hook it up. Leave your current setup alone, and just hook an optical cable from the tv to the sub.
Apr 02, 2013 | Samsung HW-E550 Crystal Surround Air Track...
I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
May 21, 2010 | Lexicon Omega Pro Studio External Sound...
Black screen and a white oblong in the top left hand corner of the moniter flashing very quickj ly on and off.The pc will not let yo do any other task. This is a wireless mouse and key board set up. Many...
Disconnect all the cables from the sys and press and hold down the power button for about 30 seconds.
turn on the sys and keep tapping the F10 key on the keyboard to boot to BIOS and set it to defaults. Restart the sys
If this doesnt work out than you need to disconnect all cables from the system and open the chasis.Reseat the RAM , VEDIO card and the cables for the HDD.
Close the chasis and connect all the cables back in their place.
Try turning on the sys if it doesnt turn on that means the system has an hardware issue and needs hardware repair
Feb 03, 2010 | HP Computers & Internet
Light comes on: Traction engaged and goes on and off. Also the anti-loc traction control light comes on and off on Cadillac 1997
My friend; Try this; Check the fuses / relays boxes in both cabin & engine compartment. Make sure there is no burned fuse or relay. U can check them visually & or using digital multi tester DMM. Check the brake peddle switch. This system {TCS} hooked up with ABS system & ESS & could be due to leaks or malfunction in the brake & or ABS sys. NOTE; TRY TO RESET THE SYS. BY Just ; 1. Dis-connect the battery negative cable, while the ignition switch in the ON position {Don?t Run the engine}. 2. keep it Dis-connect for at least 15 minutes { some experts said 13 hours """ Overnight""" }. 3. Re-connect the battery negative cable, put the ignition switch in the OFF position {Don?t Run the engine}. Then NOW run your engine & see if it disappears. Try it, & PLZ; let me know if I add any benefits to you. I hope I add some thing valuable to you. Regards; MAR; soer2@yahoo.com
Nov 09, 2009 | 1997 Cadillac DeVille
Missing file "lgusbbus.sys"
Any luck finding the Lgusbbus file? I need it for the same reason: to download pics to my pc.
Mar 29, 2009 | LG Shine CU720 Cellular Phone
LINKYSYS HOOK UP
connect ethernet cable of your computer lan card to ports on linksys router ethernet port.
then acee in browser tis link
http://192.168.1.1
then username is admin pasword also admin.if not login then try username blank and pasword is admin
then set dynamic ip adreses enable .asl oset in your tcp /ip properties in lancard.set it to obtained dynamic ip aderss auto.aslo make sure in link sys that dns also automatic geting from isp.
thatys it.
u get INTERNET NOW FROM YOUR ISP.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Hooking up my printer
I am trying to hook up my printer to a different pc and it will not print...on the paper it prints unsupported personality:PCL...does anyone know why it's doing this??
Jun 24, 2008 | Office Equipment & Supplies
SYS Technology monitor SYS-152L-C-JT
What kind of cable do you need? Data cable?? you can use from the other old crt monitor.
Power cable?? is the same cable from desktop cpu computer. Are the same type.
Sep 06, 2007 | Sys Technology SYS 152L-C-JT (Chrome) 15...
Linksys Wireless-G Broadband Router Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
