Question about Sharp VE-CG40U Digital Camera
Transferring images How to transfer images from Sharp VE-CG40 to PC
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com )
Posted on Apr 09, 2011
SOURCE:
How to clean the transfer belt for sharp MX-3140
The transfer belt should be cleaned as a part of the routine maintenance the machine does to itself. You shouldn't have to do this. Call a service tech if you need help removing it from the machine as it tears rather easily.
Copier Collin Houston TX Copier and Imaging Expert
Feb 27, 2015 | Sharp Office Equipment & Supplies
There's a black line on copies of SHARP AR-5316E
Cartridge(s) may be putting out too much toner or scratched
Aug 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Mar 12, 2010 | Canon PowerShot A510 Digital Camera
Question after I download my pictures to my pc. can I redownload the pictures back to the canon power shot a520?
As a part of the download process, most cameras and transfer applications ask you if you want to delete the images off of your camera once they've successfully transferred to your PC. Check the preference setting of the application you're using to transfer the images to your PC. Best way to check is to transfer images to your PC, disconnect the transfer cable and see if the images are still on your camera.
Nov 17, 2009 | Canon PowerShot A75 Digital Camera
Image Transfer from cell to pc
I have nokia 6210 phone and am unable to transfer image to my pc.How to proceed
Nov 16, 2008 | Nokia 2600
Sharp VE-CG40
Fixya does not supply software of any description. Contact the manufacturer or use a USB card reader.
Jul 09, 2017 | Sharp VE-CG40U Digital Camera
Sharp ar-bc260
change the transfer belt, and drums, suggest a whole Preventive Maint.. , part broken in tray 1, that is not enough detail..
May 16, 2008 | Sharp AR-BC260 Color Copier
Sharp VE-CG40
I bought this camera off ebay. I do not have any software for it. I cannot get it to transfer pictures to my computer. I think i need to install a driver. It is a Sharp 3x Optical Zoom Digital Still Camera VE-CG40. Where can I download a driver?
Dec 25, 2007 | Sharp VE-CG40U Digital Camera
Sharp ar 5316
my dear sir pleaz open the right cover and check the transfer corona wire if transfer corona is broken then replace it only.thanks or there is moisture in ur papers dry before use
Sep 10, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp VE-CG40U Digital Camera Logo
82 people viewed this question
Top Sharp Cameras Experts
Marvin
Marvin
tylerbell49
Level 1 Expert
NOEL
NOEL
Are you a Sharp Camera Expert? Answer questions, earn points and help others
