Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Need the threading diagram for the Speedylock model 1600. Please and thank you.
Had the same problem. Customer support pointed me to a different website where i was able to download it. Happy sewing! :) - Rie
To download your free copy of your “White” manual, please follow these steps:
1) Go to www.singerco.com
2) From the top tool bar click on "Customer Support", and then select “Instruction Manuals”.
3) To find your particular manual, enter WSL and then your model number (for example - WSL1600) in the search box.
4) Click on “Search”.
IF THE NUMBER CANNOT BE FOUND, THEN UNFORTUNATELY IT MEANS WE DO NOT HAVE A
COPY OF THIS INSTRUCTION MANUAL.
Posted on Aug 02, 2010
White speedylock 1600 thread keeps breaking
rethread the machine to make sure it's threaded correctly & that the thread is not caught anywhere
put new needles
check the thread tension, it sounds like it's to tight
use a can of computer air & clean out around the loopers area for lint or loose threads
if none of these suggestions work, then having it serviced would be the next suggestion
Aug 09, 2011 | White Sewing Speedylock 1600 Mechanical...
My white speedylock 1600 is being difficult.. The top threads lay and look perfect.. but the bottom threads are loose.. What can I do about this?
This machine has differential feed (top tension is different from bottom and fabric feed rate can be different from bottom). turn the dials for tension and feed rates to adjust. Adjust bottom tension to tighten bottom threads and possibly speed up bottom feed rate. Tough to say without more info.
Good luck and please rate me.
From White Sewing web site.
"Are wavy fabrics making you seasick? Do puckers leave a sour taste in your mouth? Then you need differential feed. It eliminates distortion and wavy seams when serging knits, plus it prevents puckers and pulled seams on lightweight fabrics. Turn the dial again for instant gathers.
Nov 23, 2009 | White Sewing Speedylock 1600 Mechanical...
White speedylock 7340 loose/missing stitches, up.looper unthreads
All tensions should be on 4. Also, make sure the threading is done correctly. Or if you wish; You can contact me on other sergers for sale. "Best prices guaranteed"! rick_coccia@yahoo.com
May 21, 2009 | White Sewing Speedylock 1600 Mechanical...
White 1600 speedylock
when you get to the end of you stitching continue sewing for a few inches off the fabric (this will not hurt the serger) making a tail of just stitches and you will be able to clip the string and take your fabric off the serger- the threads should be wraped around the looper as you described. Let me know if this works for you
Jan 10, 2009 | White Sewing Speedylock 1600 Mechanical...
White 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
Jul 07, 2008 | White Sewing Speedylock 1600 Mechanical...
Keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
78 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
