Question about Poulan Garden
Trimmer starts but the spool wont turn anymore
Weedeater Featherlite gas trimmer starts up but wont turn anymore?
  • 3 Answers
You're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
Posted on Aug 01, 2010
Where do I find the model ### ?
The model number is the 952711334 This is an XT200 Featherlight manufactured in 2004
Jun 21, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Does poulan featherlite weedeater have a compression releif valve
It barely has a motor. No it has no need for compression relief.
Aug 11, 2012 | Poulan Featherlite Plus Gas Trimmer
My Featherlite Weedeater shocks me when I touch the rod that the spool is attached to. ( I am a woman, can you tell, lol) The only thing I can figure out is the repairman took off the rubber sparkplug...
Yes, that is the problem if the metal loop is touching part of the trimmer. If it's not touching anything, I guess it's possible that the spark could be jumping; causing the whole trimmer to be electrified...Yikes!! Are you touching the spool while it is still running??!
Jim
Aug 25, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Hello, I have a Weedeater Featherlite and can't find the manual. I used up the line, and bought replacement line (didn't see replacement heads.) I guessed at how to wrap it on there, but I can't release...
The Featherlite should use .065 trimmer line and has to be wound the OPPOSITE way the head turns. There should be an arrow on the spool showing which way to wind line.....
Jul 05, 2009 | Garden
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Sears featherlite weedeater wont start
Needs carb rebuild kit and carb rebuild,likely its one of those carbs made in china.
Jun 06, 2009 | Homelite Mighty Lite Lawn Trimmer
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
782 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
