Question about Haier HPAC90ER Air Conditioner
The Model # is HPRD12XC5. A red light went on next to the AC fan
This red light went on when the AC was turned on. For some reason - and this is what we're trying to find out - the unit shut down one night.
The water pan in the bottom was probably full. Did you try to drain it? First uplug the machine from the outlet. There should be a little knob to unscrew in the lower back of the machine. Once you remove it, pull out the little black stopper and have a very shallow pan ready to collect any water. Once everything is drained, replace the stopper and the knob, plug it back into the outlet, and press the reset button. Turn the unit on and wait a couple of minutes for the compressor to start.
Posted on Aug 10, 2011
Check engine light
Hi:
Your Honda Civic has 2 fans: One fan is for the engine cooling, and only comes on and off when the fan thermistat tells it to. the other fan is the AC condenser fan, and it is on when the AC is running, which it is supposed to do. You need to have a code reader attached to your car to figure out why your check engine light is on. Most Auto parts stores will do this for free, and then you will know why the light is on, and can work on what it will take to fix it
Sep 28, 2013 | 2003 Honda Civic
1998 Toyota Corolla radiator heats up (gauge goes full) every time I turn on the AC Fan for 5 to 10 minutes. This is happening with or without AC on. This model has Fan seperate from AC which gets turned...
Most overheating problems are caused by a stuck closed thermostat, if it has already been replaced the next common cause is a clogged radiator, have it checked at a REAPIR SHOP OR RADIATOR SHOP IF YOU REMOVE IT YOURSELF
Apr 03, 2017 | 1998 Toyota Corolla
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
The N64 light won't run on.
The N64 is pretty forgiving... try this. Plug the AC adapter in and the system leave in and turn OFF for 1 hour.. if the AC Adapter doesn't get warm then u name have a bad AC adapter... replace it and hope for the best!!
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Aug 20, 2009 | Nintendo 64 Console
For some reason my AC started making a clanging noise. Upon checking I found that the blades went flying off the fan. How can I fix this
need a new fan blade. might want to check out your local wholesale parts store. make sure you take unit model # and s#
May 23, 2009 | Haier (HPE09XC6) Air Conditioner
Hit test/reset button now won't turn back on???
Test, reset sounds like a GFCI. is the machine draing properly? Sometimes the fan will blow , splash water and cause a ground fault. It wouldn't hurt to check the outlut and the breaker controlling it. Just plug a lamp in and make sure there is power.
Good luck.
May 22, 2009 | Heating & Cooling
Tv wont turn
replace the AC fuse, a GMA 6.3 amp fuse. I have seen many of these sets where the AC fuse opens for no apparent reason.
Jun 18, 2007 | Panasonic CT-36HL43 36" TV
Haier HPAC90ER Air Conditioner Logo
266 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
