Question about Craftsman 20 hp 42 in. Deck Yard Tractor
2010 Craftsman Lt 2000 deck height adjustment?
I have a 2010 Craftsman Lt 2000. 42" deck, model #247.28904. I just cut the grass for the first time and have the deck raised all the way up. The grass is still way too short. Is there a way to adjust the deck height other than the deck lift lever?
Just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Posted on Jul 29, 2011
    New Friend:
Park your rideon on a level surface (concrete), disconnect battery, adjust tyre pressures to the correct PSI, lift deck to position 6, place 4" blocks of wood under deck, 2 blocks under the back edge, 1 block under the front edge near the midline, that takes care of your deck being level, next slacken off all the adjusters usually 4, then tighten the adjusting nuts until they just 'catch' and then tighten the lock nuts, all done.
If you run out of adjustment you may have to re-try either a 3 1/2" or 3" blocks of wood.
Don't bother with trying to make the front edge 1/8th of an inch lower at the front, it's not a Swiss watch you're trying to adjust.
What you will achieve is a perfectly level deck, and the maximum deck height that your particular rideon will take, and finally no scalping.
One final adjustment, set height lever to position 3, (once you have done the previous adjustments), then position the small jockey wheels so that they only 'just' touch the concrete.
Then you're good to go.
Posted on Mar 31, 2016
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi, got a Craftsman 20 Hp 42 inch cut , the Deck will not lay flat, it is always on a angle. any ideas ? No matter what the cut height is set at.
Hi tubbed,
Most of these decks are held on at three points. Two are in line 90 degrees from front to back. The other is attached to the height adjust lever.
The first two are adjustable to change the type of angle problems you are having. Make sure you have the engine off when checking. Adjust until the desired angle is reached.
Also, if the model your problem is categorized under does not match your model, the cause of the angle and the solution may be different.
Best regards
Mike
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I raise the blades
there should be a big bar on the right side of the mower that changes the deck height. if it only going up a little look for a height limiter dial on the other side of the mower about where the height adjustment bar is on the right side.
good luck and be careful!
Jul 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42" deck not cutting level
I had a similar problem, and the problem was fixed by airing up one of my front tires. This may not be all of the problem, but you should eliminate this before you go adjusting.......
Just a thought, --W/D--
Aug 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Uneven cutting height
Hi Matt,
Thanks for the update. Good ole brainstormin' comes through again!
Charlie
May 07, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
1,570 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
