Question about Admiral Refrigerators
ADMIRAL NNT 196D refrigerator tries to start hums briefly then clicks off.
  • jhedwards127 Aug 01, 2010
    Admiral NNT 196D
    WILL NOT COOL
    WHEN PLUG IN SOUNDS AS IS COMPRESSOR TRIES TO START AND THEN CLICKS OFF. FAN AND LIGHT ON.
    DOES THIS MODEL HAVE A START RELAY OR JUST A RUN CAPACITOR?
    Well done! Thanks,
  • 10,515 Answers
This is a common problem on most of the refrigerators.Either it is a faulty compressor or the start device on the compressor.If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Other option would be - Go to a local repair shop and get an overload and relay ( cost around $50 ).Replace it. If the problem still persists, then it is faulty compressor.
Compressor's usually have 5 years warranty on it.
Good Luck!!
Thanks!!
Posted on Aug 01, 2010
  • 3,230 Answers
Well most of the time these sound comes because of overload so first of all you can please follow the below steps -
1. Pull the refrigerator away from the wall and unplug it. Refrigerators are very heavy, so get help moving it and do not tip or rock it.
2. Find the condenser coils on the refrigerator. These coils disperse heat, so cleaning them improves the effectiveness of the refrigerator, and stop humming sound.
3. Remove the dust build up on the condenser coils with a vacuum cleaner or condenser brush. If there is a large amount of build up on the refrigerator coils, you can use mild soapy water to more thoroughly clean them.
4. Clean the grill on the front of the refrigerator as it will also help eliminate the humming noise. The grill on front of the refrigerator should snap off and on, but check for screws first. Then pull firmly toward you to remove the grill. If further you have the same problem then there must be some problem in Relay, and you need to replace them. Please post comments for further help or information........
Good Luck!!
Thanks
Posted on Jul 31, 2010
  • 1 more comment
  • jhedwards127 Jul 31, 2010
    What relay's. Does this model have a start relay or a run capacitor?
  • Mukesh Kumar Jul 31, 2010
    The refrigerator relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is located on the lower rear of the refrigerator. Remove the cover on the compressor relay box. The cover is usually held in place by retaining clips or tension clips. There are usually three components inside this box: the compressor relay, the compressor motor terminals and the overload protector. The compressor relay is the largest component and will either be wirewound or solid state. you need a multimeter to check that Relay.
    What am I looking for when I test relay?
    Can you tell me if this model has a start relay or just a run capacitor. When I plug in, I get a brief electrical sound as if compressor trying to start, then clicks off.
I have an Admiral side by side model LSD2615HEZ that is not cooling. I can hear the hum of the condenser, but do not hear fans kicking on when I turn the temp gauge from 0 to 9. I don't hear a click or...
Do you hear the thermostat control clicking off and on if so turn on set about half way and remove cover from back and see or hear if the compressor and motor are running if not you need to replace the starting components go to a appliance store and buy a 3 in 1 kit and follow the diagram for installation make sure you disconnect the power before working on it. good luck and please leave me feedback so I know it works.
Feb 04, 2015 | Admiral 26 cu. ft. Side-By-Side...
I have a admiral aed4475tq less than a year old and it just stoped and wont restart
Does the motor hum when you try to start it in the above mentioned manner? Does the door switch click when you push and release it?
Feb 14, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My 2005 Admiral side by side has stopped keeping things cold everything in the freezer has thawed and the fridge part is now over 70 degrees there is power as the lights are on and it sounds like the ice...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Admiral 26 cu. ft. Side-By-Side...
Admiral HMG61139 21.1 cu ft Side-by side refrigerator, not cooling. clicking sound every few minutes. (sounds similar to oven thermostat or relay coming on).
Thier is one of a couple things going on with your refrig.
The start relay on the compressor is bad so what your hearing is the overload thermostat tripping on and off and keeps trying to start the compressor
The fan motor by the compressor called the condenser fan motor is not running to cool the compressor so once and what you overload keep trying to start the compressor but its too hot to start
Finally the compressor is locked up and the overload still keeps trying to start it but its totally seazed and ain't going to run
I hope this helps you to determine what is wrong with your refrigerator,
Gene
Aug 10, 2011 | Admiral 26 cu. ft. Side-By-Side...
Admiral freezer not freezing ice cream
heatman101
Jul 31, 2011 | Maytag Admiral Top-Freezer Refrigerator
Water Dispenser of Side by Side ADMIRAL Refrigerator Not working
check water flow were water connect may be is your water valve if you have water filter change it
Apr 04, 2009 | Admiral 26 cu. ft. Side-By-Side...
GC2224gek admiral freezer keeps defrosting and the food thaws. The fridge is working. Switch it off for a day and fridge, freezer and ice maker works. After a few days it starts defrosting and I noticed it...
I believe your defrost control board is defective part number 0165748 You can visit my site below and enter the part number or the model number GC2224GEK in the search feature. We also offer free help, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
I need to replace the evaporator fan on my Admiral refrigerator NNT-196DV. How do I get to the fan?
Type your model numer into the google tool bar, you should get a few links to diagrams, if your'e handy you should be able to figure it out.
Mar 18, 2009 | Refrigerators
Admiral Refrigerator/Side by Side
compressor or sealed system issue compressor is failing or a problem in the sealed syetem is putting a back pressure onto the comperssor causing the compressor to eventualy kick of on the internal overload in the compressor, cools down as you unplug the unit allowing the compressor to cool down resets the internal overload runs and repeats the process
have the unit checed by a quilified tech in ref sealed system repair
May 27, 2008 | Admiral 26 cu. ft. Side-By-Side...
sounds like the compressor is bad, do you hear a clicking sound when you turn it on or when it's trying to turn on?
Mar 30, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
