Question about Sears Exercise & Fitness
Proform crosswalk 525s the belt won't move
When i turn on the machine DIsplays seem to work fine and acts normal but the belt won't move. what can i do to fix it?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 13, 2010
How do I get the belt unstuck from the right side?
You will need to loosen up the right side one revolution, then run the belt at .5 revolution. Watch the belt then retighten the right side slowly until the belt stays in the center. Once its running in the center for at least 1 min without moving over more to right you can stop tightening.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jul 17, 2015 | Proform Crosswalk Advanced 525x Front...
How do you keep belt from slipping
see the video attached and proceed according. God bless you
Dec 13, 2012 | Proform Crosswalk Advanced 525s Walking...
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
May 11, 2012 | Proform Crosswalk Ls Treadmill Walking...
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
When i try to run, it stops and then goes. Its like its trying to hard to go, you cant even run. its a proform crosswalk caliber.
hi it seems like the belt on the motor has either slipprd or needs to be tightened, i had the same problem. i just tightened the belt on the motor and its working fine!
Nov 20, 2010 | Proform Crosswalk 500 Treadmill
THE BELT MOVES FINE BUT WHEN I STEP ON THE MACHINE THE BELT STOPS
the drive belt is slipping under the motor hood and most likely needs replaced
Aug 02, 2010 | Proform Crosswalk 500 Treadmill
Belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
May 26, 2010 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
103 people viewed this question
Top Sears Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Sears Exercise and Fitnes Expert? Answer questions, earn points and help others
