The top/ spiral portion of my agitator is not moving as I think it should. Is that the DOG TEETH? looking inside the top I can see some worn gears. Please tell me this is a cheap easy fix.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Posted on Jul 31, 2010
Whirlpool top loading cloths washer agitator is loose when it should be turning. how do i tighten it?
Sounds like you might have bad agitator dogs. Remove the agitator cap, theres a 5/16th bolt that needs to be removed then the top of agitator comes off. The dogs are 4 little gears with teeth on them, when they get worn the top half of the agitator doesn't move.
May 09, 2011 | Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Why wont the top portion of my agitator spin? It appears there are plastic gears within the top portion of the agitator. Can these be inexpensively replaced?
Whirlpool, Roper, an Kenmore are the only brands with rebuild able agitators. Any other brand will need a replacement agitator. The parts are about 6 to 8 dollars.
Here are some instructions I recently posted for someone else with a similar problem on an older whirlpool washer. If you need more specific instructions or the model you have is different let me know and I can look up the parts breakdown and give you step by step repair instructions.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to separate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 30, 2010 | Washing Machines
Agitator just clicks when it should be moving. Will not move in wash or spin cycle. Please advise.
Agitator has 4 Teeth - Dog Teeth I Beleve the name is in top part of Agitator. Take softener cap off top of Agitator. There is a plastic cover under softener cap. You need to remove plastic cover then you will see 4 teeth that lock into the agitator replace all 4 teeth make sure you put the teeth back in the same way or it won't work. Old teeth are rounded and won't grab Agitator anymore. Job not hard.
May 17, 2010 | Washing Machines
Whirlpool ultimate care II, Top agitator not working. I got it apart and can see the agitator dog gear not catching, unable to free the gear from the clips. Suggestions?
stand on agitator,pull top section upwards,the agitators are meant to be disassembled this way,sometimes they are stubborn,and you cannot service agitator if agit is still in the machine...
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Agitator will not make contact on every turn/hit and miss
Hi, The dog kit is bad inside the agitator. Here is how to change them.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stripped gears
It wasnt necessary to remove the shell. The agitator dogs can be replaced from the top through the lid.
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The top part of my agitator moves slightly, and sometimes not at all. The bottom part moves but the clothes at the top don't seem to move.
The top agitator has small plastic mechanisms called "dogs" which engage the upper agitatior when needed. If the top agitator spins in both directions by hand, these gears are worn. To replace them, remove the top center cap by pulling straight up on it. This sometimes requires a good deal of pulling force. Then, if you look down in the center hole, there will be another cap recessed in there. You remove that by pulling up on it as well. Then there will be a center bolt which has to be removed. After that, the top agitator will pull off and you can look down and see the dog gears (usually 4). They are readily available and cheap. Note: I recommend replacing the cap o-ring when doing this repair.
Oct 21, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
