Question about Scosche Industries GROUND DISTRIBUTOR ONE 4GAUGE IN FOUR 8GAUGE OUT
How do i put wires on distributoir - Scosche Industries GROUND DISTRIBUTOR ONE 4GAUGE IN FOUR 8GAUGE OUT
  • 229 Answers
You are going to run a 2 or 4 guage wire from your battery into the input side of your distributor and then insert seperate wire for each of your devices. remember the bigger the better.
Posted on Aug 01, 2010
Howdo. I. Put back the wires on my damon intruder.with 2slideouts.
check to see which wire goes to the frame that is ground the one with the fuse is hot wire once connected and working mark them
Aug 04, 2015 | Damon Motor Coach 2008 Tuscany 4072
Put a plug on a 220 wiring. the plug has melted
buy a new power cord with plug on it, remove back of dryer, undo screws on old cable one at a time and install new wire: example---remove a red wire from old cable and then put on the new red wire , move to the next color and repeat. put on back, then plug in. Done...
Jan 08, 2014 | Dryers
How do you replace rear speakers in a 2002 Alero?
Put the + from the "sub wire" to the + on your new speaker. Put the - negative from the "tweeter wire", to the Negative of new speaker. Now, take the Neg. from "sub wire", and connect it with Positive from "tweeter wire". This is called wiring in "Series". This keeps the ohm load at a level safe from overheating your speakers. Click this link: http://bcae1.com/ put "series wiring" in a search on that site, and the page will come up that has a picture, as well as info of why you should wire them like that.
Aug 06, 2011 | 2002 Oldsmobile Alero
I have a honeywell RTH111/RTH221 I put de red wire ont Rh, but where do I put the black wire? Thanks!
If you just have two wires and it controls heat only put black wire on W, or W1 if there is no plain W
Jan 22, 2011 | Honeywell Programmable Thermostat Heater
Two function control switch. Broan nu-tone
Oh Boy! ...Oh Boy! Lol...:) Put the Earth/Ground, (usually green and yellow) wire in the on screw side.
Then, get the Fan's black wire, and connect with the Light's white wire,...then put it in the any one of the Screws, (usually a hole where you put a wire through and screw down to hold. Golden ~ like in color).
Then, get the other Fan's white wire, and connect with the Light's black wire, then put in the other Screw hole. :)
And Whala :)
Mar 28, 2010 | Broan-NuTone FAN CONTROL SWITCH
Amp
you want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Mar 25, 2010 | Ultra Linear UL801 Car Amp
My fan has three wires, black white and blue. It had no manual and I wonder how to wire it to the on/off switch.
Put the black and blue wire together with the black wire on ceiling. Put the White with the White wire on ceiling. Bare/green wires are ground put them together.
What fan wires do.
The black wire is to power the fan motor.
The blue wire is to power the light on fan.
The white wire is neutral.
If you wire this way you turn on the switch and use the pull chains to control the fan and light.
You can also buy a remote control unit at a home depot. And it will have instructions on how to hook to fan and ceiling.
Jan 02, 2010 | Hampton Bay 52 In.Carriage House II in...
I asked earlier about if I had to align the timing chain on my 1996 hombre so the #1 pistoon was at TDC. The answer was yes from you. Thanks for help. One other question is, how do I do this. Do I remove...
Yes you can do tht, align the crankshaft to its mark at TDC and after removing the spark plug use the dip stick to confirm the piston # 1 to be at the top.
Best would also be to remove the valve cover and thn to check the valves (both Inlet & Exhaust) at cylinder # 1 are closed, at this stage the distributor rotor should point at # 1 wire on the distributoir cap, being now the power stroke.
At this stage too you should be able to locate some mark on the camshaft.
Hope this helps!
Dec 29, 2009 | 1996 Isuzu Hombre
After putting in starter, attaching wires is HARD, any tricks to attaching wires??
You got it, we attach the wires first as you already figured out, just make sure the battery is disconnected for safety sake.
Oct 14, 2008 | 1996 Chevrolet Suburban
I have 2 dual voice coil subs and there are four connectors on one side of the sub 1 2 -1-2 how to determine wich ones go together
it depends on whether you want to wire them in series or parallel
series-put a wire between one of the red and black and leave a pigtail put another wire between the other red and black and leave another pigtail use one for positive and the other for negative
parallel- put a wire between the two reds and leave a pigtail put a wire between the two blacks and leave a pigtail- use the blacks for your negative and the reds for your positive
1=positive(red)
2=negative(black)
if your amp has a 4 channel output don't wire the 1's and 2's together- .wire them in pairs of 1 + 2 to each of the amp outputs
Apr 09, 2008 | Audio Players & Recorders
Scosche Industries GROUND DISTRIBUTOR ONE 4GAUGE IN FOUR 8GAUGE OUT Logo
26 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
