My laptop gets overheated and sounds very much. After some 3-4 hours its reboots itself,
    Sergeant:
    Champion:
  • 277 Answers
Ok,
Are you up for the challange?
Hopefully we can save your machine.
Turn over you notebook and remove all screws. As you are removing the screws put them inaway where you know wher that screw came from.Some of the screws will let you open some of the doors protecting Harddrive, memory, wireless etc.
One screw will help remove the CD
If you feel brave enough slighty remove bottom if possible... you'll fine a huge ball of dust and fluff which is why your system shuts down.
After removing fluff and dustball put machine together and start my machine.
Now if this is too much for you find a good computer Tech you TRUST. have him do the job, It will cost about 60-80 dollars
Posted on Jul 31, 2010
    President:
  • 2,571 Answers
Your fan may be broken or just clogged with dust and dirt.
Try an "AIR DUSTER" fo blow the muck away.
If you run it untill it reboots, you could be damaging many parts, CPU/GPU and other chips.
check youtube for tips on cleaning laptops
For a week now my laptop has been overheating,then will shut itself down,the overheating happens rapidly,all internet connections have slowed exponentiallyy as a result,is it fan related?the laptop is
The laptop will need to be dismantled down to the motherboard level, use a can of compressed air attach straw and blow out all ports, heatsink and fan. It might be a good idea to remove both for closer inspection and several good blast of air for good measure, and check the thermal paste between the heatsink and processor ic has not dried out.
Apr 09, 2012 | Compaq Presario CQ62-112TU
Computer shuts off at random
It sounds like it's overheating, check your fans make sure all are working, if your fans are all working then your power supply is overheating and should be replaced. If your system is a laptop the battery can overheat also and shut the system down. So you can have different issues dependent on laptop to desktop.
Feb 03, 2012 | Gateway Computers & Internet
Why does blue screen appear suddenly sometimes interrupting my work and all of a sudden the computer restart by itself?
This sounds like a memory problem
try this: goto control panel, system, advanced, performance, advanced, virtual memory, settings
set start size and max size to same
mine is set at 2500
Apr 20, 2011 | Microsoft Computers & Internet
My laptop gets heat and shutdown
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Feb 27, 2010 | Compaq Evo N610C Notebook
Lap top keeps rebooting
Sounds like it could be an overheating problem if it happens after a long period of operation. Try downloading a hardware control utility to check the CPU temperature and control fan speed. look here
http://www.howtoarchives.com/2009/12/fan-control-speed-for-laptop
Of course this assumes that you can reboot after the pc is switched off for a time.
Feb 10, 2010 | Toshiba Satellite A10-S129 Notebook
Hp g60
it my be overheating if the fan isnt working
Dec 13, 2009 | HP G60-120US Laptop
Dell Inspiron 1420 shuts down instantly randomly. Then you have to reboot. Sometimes it does it repeatly others it doesnt. I have formatted and done a fresh install but the problem continues. I have also...
if you're not getting the blue screen of death it sounds like a hardware fault. If it's not too old contact dell. It could be something stupid like a duff battery connection
Oct 24, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
My router resets itself over and over happens
most routers have an overheating reboot protection. Dust it well with compressed air and get it in a cool place with forced air induction to cool it. We have this issue with many routers at work. Unfortunately once it's been heated up, it reboots much more.
Apr 19, 2009 | Arris Touchstone 450a (CM450) Modem
Overheat?
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
