Question about Hobart HR7E Electric Single Oven
HR7 No Electronic Readout
I purchased a Hobart HR7 and and HR5, both double stack at an auction. The lights work, the rottisseries turn and the ovens heat up but I don't get any any readouts on the electronic programmable control. It looks like the programmable readout is hooked up (I pulled the side panels off) but it doesn't turn on. Is there something I need to get this function to work?
  • 3,037 Answers
I think it is either a fuse or something that burned out that won't let the display show up. Check all solder points on the inside and see if any are broken for sure. Nothing looks bad does it?
Possibly this is why it was at auction...
Let me know if you still can't figure it out and I will see what else I can come up with.
Thanks
Posted on Apr 24, 2008
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
How do I fix hobart convection oven door chain
Check the bottom hinges, one of them should have a roll pin, the pin might be broken
Oct 03, 2012 | Hobart HEC202 Electric Double Oven
I have just installed a Maytag built-in double oven to replace my old one (still working.) I shut off circuit breaker and reconnected wiring. The Control Panel and indicators on the digital readout all...
How many active terminals are there at the main terminal block in the new oven. Is this a single or 2 phase supply. Have you connected the active supply to all active terminals. If only half of the oven is working it sounds like it could be a problem at the terminal block. If so, you need to put a loop or bridge wire to the 2nd active terminal.
If all this was done correctly when connected the only other thing it could be is the electronic clock needs to be set to manual mode for the oven to work correctly.
Feb 26, 2011 | Maytag CWE5800A Electric Double Oven
LOOKING FOR A WIRING DIAGRAM FOR A HOBART HR7
looking for a wiring diagram for hobart hr7 rotisserie oven
Nov 10, 2010 | Hobart HR7E Electric Single Oven
TEMPERATURE READOUT NEVER REACHES POTENIOMETER DAIL SETTING.ELEMENTS ON OUR DOUBLE STACK 1132 IMPINGER ALL READ CONSISTANTLY 28 AMPS @ 208V.SWAPED THERMOCOUPLES BOTTOM TO TOP TEMP DISPLAY DID IMPROVE BY 50...
You could also check that the fingers are properly fitted in place at the point where thy join oven and the glass window is closed. make sure that all the elements are working well
Jul 30, 2010 | Lincoln Conveyor Oven - 1132-000-A
Dislpay is blank but oven works
HI, you will need to replace this faulty ECC. the chip set that is soldered on this board is damaged as well as the led display. replacing the Electronic Clock Control will fix this issue.
the control board is fine and this explains why the oven is still functional. its the ECC that is faulty.
Click here to purchase your new ECC online.
May 25, 2009 | Whirlpool RBD305PD Electric Double Oven
I need parts for a old covection oven made by hobart it is a large stack with no model # commercial stainless any suggestions
Remove the lower panel under the doors. You should find the data plate on the back of the panel. What country are you in?.
Feb 24, 2009 | Hobart DEC502 Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Hobart HR7E Electric Single Oven Logo
178 people viewed this question
Top Hobart Ovens Experts
Craig Butler
Craig Butler
Dan Webster
Dan Webster
Gil Shultz
Are you a Hobart Oven Expert? Answer questions, earn points and help others
