Zone cooling not delivering adequate air to both zones simultaneo
We've moved into a new home with a new York system in a 2 zone configuration, 1 downstairs and 1 upstairs, all controlled by a Honeywell controller. About 90% airflow goes to the ducts in the downstairs zone when that unit is activated, and minimal airflow reaches the upstairs. The only time strong airflow pressure comes through the upstairs zone is when the downstairs thermostat shuts off. Due to low airflow upstairs, that zone always stays hot and takes a long time to cool down in summer.
    Novelist:
  • 117 Answers
You need to have someone evaluate the ductwork for the home. With all zones calling, there should be an even balance of airflow. And when only one zone is calling, there should not be the tornado effect you describe.
The dampers feeding each zone may be of the wrong size. It also sounds as though you are also having a problem with your bypass damper. This damper is designed to bypass excess air when only one zone is calling. It is operated typically off the airflow alone.
Have it check out. You definitely have a problem. I would recommend getting it looked at by a company other than the installing company to remove any bias judgment or diagnosis.
Posted on Aug 01, 2010
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 15, 2017 | Heating & Cooling
How do I connect a 24v damper motor with 6 colored wires red white yellow green blue black to NO COM NC terminals.
Choose two colors of the thermostat wire, and connect them to the NO and COM and connect them to the zone control board leads for the zone intended. Almost all zone valves spring return open when deenergized. So ensure the zone valve is open with the system is off. At the base of zone valve there is a set screw that needs to engage the damper valve shaft in the open position with the motor in the spring release position. Most zone valve are 90 degree moment from full open to full shut. If you have a Carrier zone valve, they go full open to full shut in 45 degrees of motion. Your open stop need to be set so the valve stops in the full stop position.
To help understand the operation of a zone system, say you have 2 zone system and zone 1 thermostat initiates a heat or cool demand. Zone 2 valves energizes and shuts and zone 1 stays open and allow air to heat/ cool zone 1. If zone 2 thermostat simultaniously initiates the same heat/cool demand, the zone 2 valve opens and both zone heat/cool. When either thermostat is satisfied the opposite zone valve closes and when both thermostat are satisfied both zone valves open.
Hope this helps you understand zone operation. The same works for higher multizone systems.
Jul 27, 2014 | Honeywell Motorized Small Rectangular Hvac...
Zone control
reset the zone system and see if it still flashes
May 23, 2014 | Fujitsu Heating & Cooling
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
I have 2 zones, both of which are programmed. The display for zone 2 works fine. When I am looking at zone 1, the desired heating and cooling temps display as -- with no temps there. The system is set on...
Are these reading temps at 2 separate tstats or are you using temp sensors that send the temp back to the stat. It sounds like the sensor is not communicating with the stat.
Jun 14, 2017 | Carrier 38CKC042 Air Conditioner
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Dec 26, 2009 | Honeywell Electronic Programmable...
Zone is set to deliver AC but nothing comes out of the vents
Your duct system has dampers that separate the four zones. Even though all four sensors are working and call for a/c, you may not be getting voltage to the damper motors, which open when there is a call for a/c, and close when the call is satisfied. In certain parts of your duct system, you will find small orange or gray boxes with wires going into them. Those are the motors for the dampers. When there is a call for a/c in all four zones, check to see if you have power going to those boxes. If power is present, the motors are bad or the damper itself is stuck. If power is not present, check the master zone control.
Aug 11, 2009 | Carrier 38CKC060 Air Conditioner
No sound from main speakers.....
WHEN YOU SET ZONE 2 ON DID IT ASK YOU TO OUT PUT ZONE 2 ONLY OR MAIN + ZONE 2? IFF SO TRY SWITCHING MAIN ON AND IFF THIS DID NOT WORK MAKE SHURE SPEAKERS ARE SWITCHED ON IN MAIN MENU.
I KNOW THIS IS 2 LATE 4 YOUR NEW YEARS PARTY BUT I JUST FOUND THIS SITE 2DAY.
HOPE THIS HELPED.
CABLE GUY.
Dec 25, 2007 | Onkyo TX-SR601 Receiver
Heating & Cooling Logo
183 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
