Everything coming through my computer speakers sounds high, like elves are speaking. I have insignia speakers.
    Scholar:
  • 104 Answers
Try adjusting the equaliser settings in ur system. Then check with ur speaker volume! Also keep the volume in moderate level. That will sound good wen compared to sound at high levels
Posted on Aug 01, 2010
Why my speaker does not have any sound when i speak using my laptop mic?
Unless I'm very wrong, the microphone only works as an input into the computer, so that the computer may process sound in some certain fashion and make a recording, like an MP3, or some such.. And then, AFTER that is created, you may play it back through your computer speakers.
Jan 16, 2013 | Computers & Internet
I JUST bought a insignia speaker 2.1 (model # NS-PCS21) and the speaker plug ins are pluged right, power are plug in, the green and the red cord plugged in... i see blue light comming up. my computer sound...
Greetings - The setup (as you already know) is simple. If you have the a/c adapter plugged in, the power on and the green speaker cable in the audio out at the back of your PC and and the red cable plugged into the subwoofer and the volume knob on the the right speaker turned up that's all it takes.
The one possible gotcha I can see is if you have something plugged into the jack at the BACK of the right speaker (an AUX jack for things like MP3 players, etc.) it will override everything else.
If that's all good you have a bad set of speakers.
Regards,
Mikeywaf
May 30, 2011 | Insignia 2.1 Speaker System (3-Piece)
I have plugged my Insignia speakes into my Toshiba laptop and also into the electrical wall outlet. The power light is on, the volume is turned up, but I am getting no sound from them. Is there another...
Without the speakers is there sound coming out of the laptop?
normally you just have to plug it to the headset port, it's usually a 3.5mm hole.
Make sure that the computer is not muted so that sounds will be coming out and adjust the volume from the computer itself.
Hope this helps!
May 28, 2011 | Insignia 2.0 Speaker System (2-Piece)
Just bought new speaks and I can not hear anything.
Check the following:
1. The speakers are connected to the power supply (if exists/needed) and powered on.
2. The speakers are connected to the GREEN jack of the computer's sound card.
3. The sound card is correctly installed. If it does, you'll see a speaker icon in the system tray (next to the clock), from which you can adjust the volume. If not, refer to the motherboard installation disc to install the audio card drivers (don't forget to restart the computer afterwards)!
4. The volume is high enough and not muted - both in the player and the tray icon.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Dec 08, 2010 | Insignia 2.0 Speaker System (2-Piece)
Sound coming from only one speaker
> try to check the settings from the sound properties
Jun 14, 2010 | Insignia 2.0 Speaker System (2-Piece)
My speakers won't work
Hi! It seems that your problem is in your computer system setting. You have to install the audio device DRIVER and install it. After that, problem solve. Good luck, THANKS
May 06, 2009 | Audio Players & Recorders
check the volume on the computer and also to speaker it self.....
Jan 21, 2009 | Insignia 2.0 Speaker System (2-Piece)
There is no sound coming from my speakers..
Check to see if the speaker s are plugged into the GREEN jack on the back of the computer.
It sounds like it might be plugged into the input jack.
Hope this helps. Bud
Jan 10, 2009 | Dell HK395 Computer Speakers
Insignia USB laptop speakers
Sound like you have a shourt somewere, hard so say I would sudjest to check your speaker wire connection, it is also posible you're computer sound volume is at the lowest.
Regards
Bob
Jan 16, 2008 | Audio Players & Recorders
53 people viewed this question
 Grubhead
Grubhead
