Question about Acer Aspire™ T180 PC Desktop
Need to setup wireless for an Aspiret180
Can this be done through an USB attachment or will I need to install a card? In either case, what is your recommendation?
Thanks in advance for your help,
Rtravs
    President:
  • 2,571 Answers
Yep.. USB wireless dongle is the easy way to go.
You can get one for under £10 with free delivery from amazon, check these out http://www.amazon.co.uk/s/?ie=UTF8&keywords=wireless+adapter+amazon&tag=googhydr-21&index=electronics&hvadid=4190591456&ref=pd_sl_1n5xmo5k17_b
Posted on Jul 31, 2010
What is a USB receiver?
If your computer is a laptop, most of (all) laptops comes with a built-in wireless adapter. And if it is working, you don't need one.
If you have a desktop (a tower casing, monitor, keyboard and mouse) setup, mostly they don't have built in wireless receiver. But if your desktop is custom built like mine, I have installed a wireless card in my desktop. But not really recommended. Since it sits in the desktop tower casing and if you need to get more signal and have to move around, you get furious because it is not mobile.
USB receiver or adapter can be extended via a USB extension cable (3 meter, 7 meter, 10 meter) and put it where the signal strength is high or remove it and use it on any other computer (laptop or desktop) with a USB port.
So, if your computer is not equipped with a wireless adapter/card built in and need to have wireless access, you need to buy a usb wireless adapter. These days they are as cheap as 8$ to 50$.
Hope this helps.
Apr 29, 2014 | Dell Computers & Internet
How to connect my hp pavilion 7915 desktop to a wifi network ?
The HP Pavilion 7915 will need a wifi network adapter card to connect to a wireless network. You would need to add an wired network interface adapter card to use a wired network, instead of a dial up connection. Check the height of your computer - a "Low Profile Card" may be needed. There are several versions of the 7915.
You can get a USB network adapter or a PCI slot card for either type of network from most computer stores. Depending on which version of the 7915 you have, you may have a limited number of USB ports. In that case the PCI card may be a better option assuming you have an available slot. Other models only have one PCI slot which can be blocked by a VGA card.
What OS is on your computer? I see some models shipped with XP and others with an older version of Windows. You will need to find a card that has drivers for your OS. Finding XP drivers will be easier than those for the older versions of Windows. Depending on the unit you order and your OS, the drivers may be already be installed in the OS. In that case, plug it in and go.
If you go with a PCI wireless network interface card, turn off the computer and unplug all of the wires before opening your case. Ground yourself relative to the computer by touching a metal part of the case before continuing. Remove the slot cover screw (hex head with a Philips slot) (for most desktops) from an available slot. Push the section of the card with the gold contacts fully into the slot. Work carefully and keep the slot section of the card between the case and motherboard. Press firmly and make sure that the card is level all the way across. Then screw the slot bracket down. (Note: you could remove the fax/modem instead of the cover if you do not need the modem.)
For a USB interface option, just plug it in. When the drivers are installed (follow the directions), attach the wifi antenna (if needed). Try to identify available networks (in XP click Start > Control Panel > Network then go to the network wizard to add a new network). Use the network ID and password for your wireless router. (I assume there are other wireless devices and the router has been set up; many older models need to be attached to a computer via a wired ethernet port for the initial set up. Most models have an initial name and password that should be changed.)
I hope this helps. If you have additional questions, please provide more information about your computer's OS and available expansion options. Also indicate what router you are using.
Oct 27, 2012 | Computers & Internet
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
How do I hook up my DSL modem to my old computer? I have an HP Pavilion Samsung SyncMaster 750s DESKTOP PC. I need to access the internet on my PC but it doesn't have an ETHERNET JACK. I also no longer...
Which HP Pavilion do you have? The Samsung SyncMaster 750s is your monitor. What OS is it running?
Most desktops that came with Windows 95-XP have a few PCI slots inside the box. Computers with Windows 98 (some with Windows 95B) have USB ports. (Older computers may also have ISA slots inside the box.)
If you have a USB port, you can use a USB to ethernet adapter. This will be limited to the speed of your USB (not a good choice if you have USB 1.1). The wired versions are limited to 10/100 Mbs maximum internet speeds. There are some wireless versions as well. See http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=589&name=10-100%20Ethernet%20USB for examples of wired adapters.
A better choice is the internal one. Again you need to check the specs for your computer and see if there are any available slots and the type on the motherboard. See HP support for the specs of the computer. Slim case formats often have few available slots. (You can usually remove the internal dial-up modem and replace it with the ethernet card.)
These are either wireless and wired. Some run at 1Gbs speed. You will also need a wireless router if you use a wireless card. (A router is a good idea even for a wired ethernet card. It provides protection against some internet problems.) A few PCI wired ethernet are available here: http://www.newegg.com/Store/SubCategory.aspx?SubCategory=27&name=Network-Interface-Cards . Turn off the computer and unplug the wires to the computer. Open the case, remove the slot cover (or card that you will replace), push the new card into the slot and secure it. Then close the computer and connect your wires. Install the drivers (usually from a CD that will come with the card or by downloading from the manufacturer's site).Then plug an 8-wire RJ-45 cable into the jack and your broadband modem. Then set up following the directions for your ethernet system (dynamic (DHCP) or static IP address, etc). (Wireless networks you install the antenna for the card and then follow the setup instructions for your wireless router. This will include the password.)
I hope this helps.
(the exact setup will depend on the OS - see the control panel Add a network connection)
Feb 15, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
What ethernet card to install Dell Optiplex GX 240? one attached to mo works intermittently - loose.
You can use any brand of Ethernet card in this computer as long as it will fit in the case. If your GX240 is packaged in the small form factor case, you'll need a low-profile card. (Low-profile cards have a shorter mounting bracket than regular-size cards which won't fit this case.) For the small desktop and mini-tower cases you can use any card.
If you want to avoid having to open the case and fit a new card, consider a USB Ethernet adapter. All you need to do is plug it in to an available USB port and you're done. No opening the case and worrying about installing a card. These adapters are available at some retailers and through online vendors.
Whichever way you go, just be sure to go into the computer's BIOS settings and disable the integrated network connection.
Hope this helps. Thanks for using Fixya!
Feb 15, 2010 | Dell OptiPlex GX240 PC Desktop
Have 2wire gateway wireless internet device. I want to setup HP Media center PC M1160N for wireless operation.
according to amazon your system doesn't have a wireless card in it. You will need to purchase a PCI Card or USB Wireless antenna. The USB will be easier to install. Once this is installed using the instructions that come with the antenna, use the 2wire's instructions on setting up a wireless network. This usually involves using the code on the bottom of the 2wire as a key.
Dec 18, 2009 | Computers & Internet
I'm tryin to install the sierra wireless card 598 on win 98 manually. Does anyone know how to do
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
  1. you may need the sierra CD device driver that comes with your wireless card.
  2. next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
  3. depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
  4. run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
  5. after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
Nov 09, 2009 | Sierra Wireless 598U USB Modem
How to connect DSL internet to the second computer
You need an ethernet card, either hard wired or wireless to connect your computer to the DI-624.
Jun 13, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
WIRELESS CARD FOR LAPTOP
Hi
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&docid=338826
Mike
May 07, 2008 | Dell Latitude D600 Notebook
Wireless network setup
Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
1. a USB Adapter for PCMCIA as shown here; or
2. a CardBus/PCMCIA to PCI Adapter Card available here.
Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
Acer Aspire™ T180 PC Desktop Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
